VCT Tile: Bevel Edges to Prevent Chipping?
nobbyv
The NH
Installing VCT in the garage. I have a 30’ floor grate drain that I was just going to run the tile up to. This means the tile will sit proud 1/8” in that area. Would it be enough to bevel the edges that are against the drain to prevent chipping? Or should I use something else?
duneslider
Riverton, Utah
You could try but the thinner it gets the more weak. Might be worth holding it back an inch or so and putting in the little rubber transition. I think it is the flush reducer molding.
