Vee's Budget Garage
suprvee
I've been working (slowly) on my garage for past few months; I figured I'd give you guys a view of what I've done so far.
P1010526 by mightyvee, on Flickr
P1010529 by mightyvee, on Flickr
^ that's me; yes ladies I'm available! :p
P1010637 by mightyvee, on Flickr
P1010638 by mightyvee, on Flickr
P1010640 by mightyvee, on Flickr
P1010641 by mightyvee, on Flickr
P1010643 by mightyvee, on Flickr
P1010645 by mightyvee, on Flickr
P1010647 by mightyvee, on Flickr
P1010648 by mightyvee, on Flickr
P1010653 by mightyvee, on Flickr
P1010655 by mightyvee, on Flickr
P1010658 by mightyvee, on Flickr
P1010659 by mightyvee, on Flickr
P1010660 by mightyvee, on Flickr
P1010661 by mightyvee, on Flickr
^ Extra thick layer at the edge of the garage.
P1010663 by mightyvee, on Flickr
^ My biggest mistake. I got lazy, and thought the epoxy would just "fill in" the crack. Boy I was wrong.
P1010665 by mightyvee, on Flickr
^ Door repair time
P1010664 by mightyvee, on Flickr
P1010667 by mightyvee, on Flickr
^ Those are some serious wood screws to stiff up the door. Unfortunately the door was exposed to a lot of moisture in its life, causing the joints to loosen up (I think they're called mortise and tenon joints). It's also slightly warped... I really should replace it one of these days, but it should serve it's purpose for a bit longer.
P1010668 by mightyvee, on Flickr
P1010669 by mightyvee, on Flickr
^ Trying to straight the door out. It's bowed in the center; so I slightly wet the door and used 80lbs of cement to get it back into shape. It ended up being pretty close by the time I was done.
P1010674 by mightyvee, on Flickr
^ Patching hairline cracks in the walls. I've got what I think is plaster over some rock lath; absolutely no tape or reinforcement at the seams.
P1010676 by mightyvee, on Flickr
^ More repair work done with drywall. Ehh, close enough.
P1010680 by mightyvee, on Flickr
^ The door gets some good quality primer.
P1010683 by mightyvee, on Flickr
^ Natural gas pipe. I'm surprised it hasn't been run into yet.
P1010684 by mightyvee, on Flickr
^ Primer going up.
P1010685 by mightyvee, on Flickr
P1010688 by mightyvee, on Flickr
More Pictures Below!
suprvee
P1010689 by mightyvee, on Flickr
^ Splash of color!
P1010690 by mightyvee, on Flickr
P1010691 by mightyvee, on Flickr
P1010692 by mightyvee, on Flickr
P1010693 by mightyvee, on Flickr
P1010695 by mightyvee, on Flickr
^ I still need to pick up some GFCI's for the garage... But the initial wiring is done.
P1010696 by mightyvee, on Flickr
^ Light going up!!!!
P1010697 by mightyvee, on Flickr
^ Not the best solution with the plug in option; but due to limited attic access, I could not run a wires directly to each light.
P1010700 by mightyvee, on Flickr
P1010701 by mightyvee, on Flickr
P1010704 by mightyvee, on Flickr
^ The garage door clears the lights just fine.
P1010705 by mightyvee, on Flickr
^ That's close to what the "before" looked like.
P1010706 by mightyvee, on Flickr
^ Getting ready to move back in!!!
P1010707 by mightyvee, on Flickr
P1010708 by mightyvee, on Flickr
P1010709 by mightyvee, on Flickr
^ trailer stand came out better than expected. $2 Harbor Freight rubberized casters rock!
P1010711 by mightyvee, on Flickr
P1010713 by mightyvee, on Flickr
Current State:
P1010717 by mightyvee, on Flickr
Original State:
I'm almost done! I still have a lot more **** I need to move in, and clean up. But otherwise, progress is being made.
-Vee
Dan in Pasadena
Pasadena, CA
Wow, very well done. BIG congrats.
I don't think there's anything wrong with with switched plugs for the overhead lights but my OCD would make me have to shotern those cords and use some kind of plastic clips to hold them up to the ceiling.
If I can find it there's a thread on here how to make those open shelves into closed one relatively easily. The whole thing looks fantastic.
