Looking for some advice. I built my first vegetable garden this year and due to our high rabbit population I need to build a short fence around it.
This is the garden (ignore the X).
It only needs to be 2'-3' high as its already raised garden as you can see. The problem is this garden is directly across from my main entertaining area so I need to make it look aesthetically pleasing as well as effective. I want to use welded wire fencing as its nice and straight looking. The fence would be on the inside of the stone.
But the issue is with lumber. 4x4 as posts I think would just look too big and bulky for the size of the garden plus I think they are over kill for a fence thats only 2.5' high. Do you think I could get away with using 2x4 as posts? Then the issue is how to set them, I can't find 2x4 ground spikes and I don't really know if cementing them is really that needed for rabbits. Also due to the round curve of the garden in the corner I'm always looking at needing at least 2 posts in the corner to make the turn.
Any ideas/advice?
On a side note, do you think setting pressure treated posts along the inside of the garden is a bad idea? I know they use to say it was because the arsenic could leach into the soil but since they changed how PT is treated, is it still a concern?
Any ideas/advice?
