PassnThru
I've been reading about vented gas heaters here lately - I currently have a non-vented gas wall mounted heater and I have always regretted that decision. It's the usual reasons - it dumps a lot of moisture in the garage and always seems to smell. Also, if I leave it on the lowest setting it wants to keep the garage around 55 or so. I just want to keep it above freezing when I'm not using it. Of course, this is often a moot point because it will usually shut itself down after a few days thinking the oxygen level is too low. So I've been looking at the vented heaters. But I have a few questions:
- Does the vented heater really produce that much less humidity?
- Is there an efficiency loss versus the unvented?
- What happens when the power goes out? My current heater requires no power to work. Most of the ventless that I have seen would require power to work. Any way to work around this?
- With an external thermostat, how low can you go on temperature? IE - will they hold a temp like 40 degrees?
