Gopherboy6956
- Joined
- Dec 19, 2021
- Messages
- 135
Since won't be doing fascia and soffit until next spring / summer and because i'll likely be doing my insulation over the winter, it's become immediately apparent to me that I need to do something about my wide open eaves before winter.
I'll likely cut osb strips to close off the bottom of the eaves for winter regardless, but that made me think ahead to insulation and i'm struggling with what I should use to hold back the insulation.
I've seen some of those attic vent baffles and that all makes sense to me, but the thing i'm concerned about is my slope. The bottom chord of my truss is a 10/12 pitch and the top is a 16/12 pitch, and I am planning to use blown in insulation as I don't want to spend the money on spray foam and i'm not sure batt insulation wont get me to the required R49 I need to hit.
Im worried that the blown in will just pile up at the bottom of the truss and I wont be able to keep the thickness at the top. With blown in, I need at least 15" of depth to get R49, which I wont even have the space for until about 2ft up the bottom chord. Each cavity that needs to be insulated is 34 linear feet wall to wall, that's a total of 680 linear feet of insulation total.
Some pics and my truss engineering drawing added for reference.
Thank you!
Thank you!
