Venting overhead heater/furnace
mod600
Central Minnesota
Per my OSB thread I recently posted, I'm working on finishing the shop portion of my pole barn. I'm planning on getting a Mr. Heater Big Maxx 80,000 btu overhead heater. I'm planning on installing it in the corner over my front service door and aiming it at the middle of the opposite wall. I want to vent it horizontally out thru the wall of the building. Where ever I end up venting it, would it be wise to adding in a bunch of blocking to run the vent pipe thru? That way there would be no insulation touching the vent pipe. Just bore a big hole (4" I believe is the vent pipe OD) thur and run the pipe thru it and seal it up with expanding foam. Or is there a better way to do this?
Since I know my plan up front, I wanted to add any blocking in before hand and do what would make the most sense.
Thanks!
mod60
csp
Franktown, CO
What you want is called a thimble. It's two pieces with one sliding inside the other. This will keep any combustibles away from the vent pipe.
csp
Franktown, CO
danski,
Care to put that in laymen's terms and how it applies to what the OP is wanting to do? I know what Category 1 means, but most people don't.
