Ventless roof insulation options?
ching0n
I've got a truss roof garage that I need to insulate but is not constructed to be vented (no overhang/eaves and gutters in place; no ridge vent). It's got metal roof on top of shingle on OSB deck. I don't want a flat ceiling since I like having storage accessible overhead. I'm in Zone 5
1. Is spray foam the only option?
2. Could one not nail polyso or closed cell foam onto the rafters or glue said boards in between the rafters onto the deck?
3. I understand I wouldn't want any leakage from the conditioned space carrying vapor into the air gap (if nailed on rafters) to avoid condensation on the deck, though I don't know why exterior humidity leaking into the cavity wouldn't be the same concern. Can I just not spray the heck out of the deck w/a impermeable layer prior?
thanks.
strutaeng
Dallas, TX
Only way to do non-vented is to use continuous rigid insulation above the roof deck. I think you can do a portion of above deck continuous and insulation between the rafters, but I can't recall what the proportions are.
Any large conditioned warehouse-type store is pretty much insulated this way. They just require different r values than residential.
C
ching0n
I was going by this article; cathedral but same process:
