Steve Bryant
I want to show you some things in this thread over time that I’ve done to extend the versatility of my Shop Smith Mark V. The first thing that I want to show is a means of using the variable speed drive with a 5/8” Shop Smith Table Saw Arbor to turn the saw into a variable Metal Cold Cutting saw. The main ingredient is a ten inch Evolution Steel Blade (model 10BLADEST – stands for 10” Blade Steel, which I didn’t catch onto originally). I want to add here that I believe that the Shop Smith with its tilting table is a very poor table saw that is potentially dangerous especially for long mitered cuts where it is necessary to tilt the table. However, I think that it is fine for use as a table saw under limited circumstances when the table is flat. Over the years I've bought a Powermatic Model 66 table saw as my primary table saw (about 25 years ago). The Shopsmith works great for this application of metal cutting though.
In order to adapt the 1” arbor bore to the 5/8” arbor I used the included steel bushing. However, it wasn’t thick enough and didn’t really hold the blade on center (about 015” radial run-out), so I bought an additional bronze 5/8”-1” bushing at the hardware store. The reason that the included bushing wasn’t thick enough is that the Shop Smith arbor design undercuts the face of each side of the arbor so that the clamping force is outboard from the center of the blade by a couple of inches. The second bushing made the blade very concentric to the rotational axis.
Then, I also made an extension fence using ¾” plywood with a L spline of plywood. I also installed two pairs of T Nuts to bolt on the fence to the miter gage to the right of the gage or the left of the gage. Then I made a simple cutoff gage using a piece of C Channel aluminum extrusion held on with a simple 4” C Clamp. That way I can make repeated cuts to length. The miter gage fence allows more accurate and more controlled cuts. The T-nuts are ¼-20 thread and set flush with the fence due to a ¾” counter bore that’s just deep enough to accommodate the nuts. This setup will work well for straight cuts or miter cuts and should work really well for accurate fit-ups of welded assemblies.
I’ll refine this setup some over time, but the evolution blade cuts like a dream. I cranked the speed down to speed “I” (about 1,800 RPMs). The proper RPM range is crucial in order to avoid burning the blade up and having the correct surface feet per minute for cutting steel. Here is an example of a cut of about a 2” pipe.
