GCncsuHD
I have an outlet, that just happened to land in the wrong spot on my work bench. It is mounted vertically in the wall, I want to turn it 90 degrees and bring it out of the wall and into the backsplash of the countertop on my workbench. I would like to have your suggestions on this before I start.
Here is the work area and the location of the outlet.
As you can see, with the top on there, the outlet is hidden behind the backsplash, and the cover is just visible above.
I don't want to lose functionality of the outlet, and I know to be "code" it needs to be accessible.
My idea was to remove the outlet and box, (probably cut the nails from the box into the stud with a hacksaw blade), then cut my horizontal hole for the box into the backsplash, then into the wall and patch the leftover hole from the old box.
Now then, as far as mounting the new box, using an "old work" box, should I mount the box in the wall and use an extender to get through the backsplash (about 1.25" thickness from the wall)?
OR mount the box directly into the backsplash, in this case the back of the box would basically be "floating" in the wall.
I would think the first option is best correct? That would mean I would need a box extender at least 1.5" or so deep to make up the 1.25" thickness?
Thanks for any suggestions
