mnster
I'm installing a 65,000 Btu Westinghouse forced air natural gas heater. Made in 1982 this heater does not have a blower assist for the vent. So I am tossing out the idea of horizontal venting. Vertical it is, 5"type B vent to be specific. I know there are a few rules to follow like you measure horizontally10' out from the pitch of the roof and the rain cap must be above it. Also the vent must not be within 10' of a vertical wall like the house for example. But, I am planning to mount it in the back corner of my attached garage. I plan to tuck it up to the wall the minimum measurements listed on the heater which is 6". I only have 9' ceilings so to avoid smacking my head on the heater I want it close to the wall in the corner and out of the way in the spring and summer months.
The problem is when in the corner it also puts the flue exit very close to the edge of the roof. Which I feel would look kinda silly and has to be improper in some way. So do I 90 it back to the mid point of the roof? I'd imagine but I've been told I should't have a horizontal run right after the exit of the heater. That it should stay vertical to maintain good flow. I am looking at maybe 4ft of horizontal run to a 90 to maybe 5 or 6ft of vertical run. Is that a acceptable way to vent?
Pretend my chop saw box is the heater, it is my mock heater if you will as it is a size replica.
bTW, you could side wall vent with the addition of a power venter. I'm a fan to the Tjernlund product. The GPAK model should do it for you. Field controls is the other manuf of power venters.
