I picked up a used 3.5' x 6' utility trailer and want to build a 26" tall wood box for it. I'm planning to use tongue and groove redwood fence panels and have the grain of the boards run vertically. I chose these boards because I have a huge pile of oddly sized boards that I can trim to fit this project.
My plan was to glue them up and then screw some painted 1x2 on as horizontal support. Supports posted at the base, top, and at the mid-rail. The mid-rail and base would get bolted to the trailer.
A couple of questions I have initially is:
chosing the material for corner supports (2x2, 2x3, 4x4, maybe angle iron) if it's even needed.
Will gluing up the tongue and groove benefit me with any strength or will it remove needed flex, maybe just a waste of glue, or an inability to easily replace broken boards?
Does anyone have experience with using boards vertically and if so, what lessons learned can you share?
This trailer will only be used for general duty, occasional use such as home depot runs, camping, mulch hauling etc.
I'm open to any and all comments, suggestions. I appreciate your help!
