VFD and 3-phase motor on drill press
rattle_snake
Chandler, AZ
Looking to convert my Hitachi floor standing drill press to variable speed motor. Anyone done this?
Currently has a single phase 110V 1 hp motor, and typical twin belt 12 speed pulley setup. It is always set for the slowest speed, which is I believe is 210 RPM. Goal is to turn even slower, and also have some range of speed without belt change.
I bought a 2 hp 3-phase, 1800 RPM induction motor cheap, and can get a VFD for under $100. Plan to stick with the pulley system, in it's lowest ratio (8.3:1). Running VFD from 20 Hz to 120 Hz yields chuck speeds of 70 to 400 RPM.
Rick_Br
Winston Salem, NC
I've done that a few times and it is a good solution. Just be aware that depending on the VFD you may lose torque at lower frequency settings.
svtride
Yup, did a couple drill presses and a Bridgeport…works well. GFCI outlets in shop did not like VFD so had to replace outlet with standard outlet.
Firebrick43
West central Indiana
I have 5 machines on vfd and the drill press is probably the most useful.
On my drill press I used a KBAC-24D drive. It simple to operate and with no programming, just a few pots to adjust and more importantly is nema 4.
Nema 1 vfd are not ment to be installed outside of a cabinet or enclosure as someone can stick their fingers easily where they can be shocked or metal chips and dust can get into the drives openings shorting it out
tool_scrounge
Southern California
^ this. If NEMA 1, put it in a box but note the ventilation requirements.
I Usually buy NOS or lightly used brand name speed controls off of EBay vs. no-name stuff off of Amazon
jcarapet
Texas
This has been on my interest list for a while for my Shop Fox. The thing that has thrown me off so far is finding a motor with the right mount and spindle. Highly interested in this for tapping and just easier control.
Firebrick43
What NEMA size and shaft diameter is your Shop Fox currently have?
whateg01
doo dah, kansas, usa
I have a 6 pole motor on each of my main drill presses. The 1100 runs at about 60 rpm most of the time. The craftsman runs around 400 most of the time. Gobs of torque on both of them.
jcarapet
Texas
The motor plate is unfortunately pretty bare. I've measured the spacing on the plate and unfortunately it doesn't quite line up with anything exactly in the charts. I need to spend a little more time on the google machine for it. Maybe a 56c?
Beerhippie
Far NE Oregon
Thank you for this GFCI information. I did not realize that GFCI outlets came with differing delays.
I didn't either--until a new piece of equipment kept popping my GFCI breaker. Our local sparky got us straightened out and explained the delay problem with VFDs.
u3b3rg33k
Thanks for the info on the enclosure type I had not considered that.
I really like the invertek drives for this. their native sensorless vector works great:
if you want really low RPM performance, look at a purpose built motor, like one of these:
you can find them for much less than list, but they have rated torque down to 0 RPM, and are TENV.
Beerhippie
Far NE Oregon
R
rattle_snake
Chandler, AZ
Got the conversion done on this old drill press. Starting point:
I had converted it to a hybrid long ago, never ran right, eventually lost the air filter.
Left 12 speed pulley system intact in lowest ratio. Low ratio is /7 or 250 RPM from 1750 motor.
Found a new, 3 phase, 2 hp, 1750 RPM motor for $100 on fbmp. 56C mount, 5/8 shaft same as the single phase, 1 hp motor it replaces.
Mount bracket for VFD and controls.
Bought a $80 VFD, 3 hp, 220V, Nema 1. Wires protrude out the bottom. Need an on/off switch in the system so I decided to get a $20 junction box to mount the stuff and wiring in. I could have rewired and used the existing on/off switch on the head of the press. Switch in J-box consolidates the wiring. The enclosure needs to be ventilated for heat dissipation. I drilled a few holes top and bottom. Not going to run it for long or at full torque so not going all in on thermal transfer. The one mount flat head screw contacts the VFD base heat sink and bolts to metal mount so it might do something.
The control panel can be remote mounted with a ribbon cable so I did that. The box was barely deep enough and the panel had to go in a specific location to clear the rest. Retained the light feature on the press but had to rewire it for 220v and use a 220V rated bulb.
Added an on/off switch at the box so the power wiring is simplified. Removed the on/off switch on the head and put in a block off.
Bought a 25' 'welder extension cable' that is a 6-50P plug with 12 gauge wire (instead of #6 wire for 50 A). Used the molded male plug and made a whip about 8' long. Motor bolted right up no mods needed.
In general the speed lower limit is around 20 Hz, and upper limit of 120 Hz. This yields a speed range of 6x. 60 Hz corresponds to 250 RPM, so RPM range becomes 83 to 500 without belt change. The VFD has a boost feature available. To test I ran the motor below 20 Hz with a 1" twist drill and exerted as much pressure as I could. It just ate so no concern of lack of power at the lower limit. Total cost was $250
R
rattle_snake
Chandler, AZ
My 220v wiring and receptacles do not have a common wire so not a viable option. light bulb is cheap.
It is possible to get a 110V VFD, but finding a used/cheap 110V 3-phase motor is difficult.
R
rattle_snake
Chandler, AZ
I didn't see a 110 in 220v out in the cheap **** on amazon, but now I see they do exist. Probably shoulda done that. but 220V cuts all the currents in half, smaller wiring, and the receptacle was already there.
aquinob
Portsmouth, VA
Nice install. Just to confirm, you wired the VFD directly to the motor and the switch controls the power to the VFD?
mm08822
In researching this more after the “delay" tidbit, I found this on GFCI classification definitions...
https://portablepowerguides.com/gfci-class-a-b-c-d-e-meaning-with-its-trip-level/
So far I couldn't find anything related with delay, just leakage amount..
I had this exact same suspicion about it actually being trip level vs a time delay. UL 483 (IIRC) only specs a max time that devices must trip. Most devices do actually trip much, much faster than the requirement.
Anyway, I never took a 2nd look into it. Class D gfci devices do trip at ~20mA as compared to Class A tripping at 4-6mA, however.
u3b3rg33k
i don't think you can get a class D gfci in 5-15 format though. something about how 20mA isn't sufficient to protect life.
mm08822
He never stated format. Class D is intended for equipment protection but still follows UL 483 if a listed component is used..
loganb
Omaha, NE
I did this to a Powermatic DP and documented it starting about the post below, I wander "a bit" on projects so will probably have to go a bit to get to the end but 2-ish years later and 0 issues with the setup so far.
R
rattle_snake
Chandler, AZ
you mean a neutral?
yes, transformer center tap connected to dirt.
Yes. The on/off gates power to everything. Big red button when bit hooks the workpiece and spins it.
I didn't see a way to 'turn off' the VFD, but maybe there is a way or sleep mode.
I would bet that if I change to a 110v input VFD that it would trip my GCFI, because murphy's law.
Amazon has a turd for $30 more that is rated for 2 hp.
R
rattle_snake
Chandler, AZ
Damn you for posting such a **** drill press. Makes me feel inadequate about the aesthetics of mine. The pulley lid is just so cool.
R
rattle_snake
Chandler, AZ
On another forum a control idea for power tapping was shared. Use two digital inputs on the VFD for a push buttons. One to go forward slow and another to go in reverse slow.
whateg01
For power tapping on a vfd machine, just wire it to run in reverse with a toggle switch and have a push button to override that and run forward for the actual tapping itself as soon as you release the button to go forward the machine will reverse on its own
R
rattle_snake
Chandler, AZ
auto reverse, so
1) flip sw to reverse rotation (motor not running)
2) press button to tap in FWD.
3) release button to get REV.
(repeat 2/3 as needed by just press/release)
4) push stop button
(flip switch back to do other stuff)
opposed to:
1) press button to tap in FWD.
<auto stop>
2) press other button to get REV.
<auto stop>
(repeat 1/2 as needed)
mm08822
This may have been the solution to the gfci recept tripping issue mentioned earlier in this thread.
u3b3rg33k
sounds like this is new old news:
that said I'm all for breakers that don't annoy me.
