VFD for lathe
dankeenan
I have a 3hp induction motor on my metal lathe. I only need to run the motor at constant speed (lathe speed is controlled via gear changes). Can I use a standard VFD (non sensorless vector)?
rsanter
visalia ca
if you use a VFD you can just leave it at 100% to drive the motor full speed. but you may find that you will actually want to make use of the variable speed at least a little bit.
for my mill I use the VFD to do some adjustment of speed. if I need to change the cutter size drastically then I move the belt
bob
D
dankeenan
I use a sensorless vector VFD for my mill also (older series 1, so I do not have to change belts). My basic understanding is the sensorless vector allows you to run near full motor output at any speed. I run my mill at 5hz sometimes when I am tapping. I set the belt at one position and only change from high to low.
But on a lathe, I have all the speeds I need via the gear head. If I can save some money, I would rather not spend the extra on the sensorless vector feature.
tdkkart
Eastern Iowa
You'll REALLY want the variable speed feature once you've used it. Infinitely variable speed is really handy.
