toolferone
I'm in the process of hooking up my first VFD. A Teco FM50. I tested it on the bench first the basic setup went fine without any external switches or the potentiometer yet. I hooked up the potentiometer and reset the parameters on the function key and tried it it works sort of, it won't go below 60 Hz it goes from 60 to 100. I have the VFD range set from 0 to 100 Hz. I have confirmed that I have a three wires hooked up correctly. What are you thoughts on this? It is a cheap Chinese 10k pot. My first thought is just to wire up one of the extra pots I have and see if it does the same thing.
