Vfd powered from rpc?
jar944
Northern VA
I have a 20hp rpc and a bunch of various vfds powering my woodshop 3ph equipment with no single motor over 9hp/6.6kw.
I just picked up 24" 15hp planer (17hp with the feed and table motors incuded)
So now I find myself trying to figure out how to power the thing. The rpc isn't going to start it (at least in its current delta only starter)
I could look for a star/delta starter, or a soft start and possibly make one of those work. However I was wondering if I could just use a 15hp vfd running off the rpc for a soft start.
My last choice is a motor swap down to 10hp, though that may be the cheap/easy option by using a 2nd hand surplus motor.
J
jar944
Northern VA
That motor cannot be started Y - ∆. It can be started part-winding on 208 - 230 but I doubt it'd help much.
I've never seen a VFD supplied but a rotary phase converter, I doubt the VFD would tolerate the voltage imbalance.
Ha.. I never even bothered to look at the lead count on that data plate.
Stuart in MN
Minneapolis
Assuming this is a residential electrical service, your utility may have regulations that limit motor sizes - a 15hp motor may too big.
American Locomotive
Rhode Island
A VFD likely won't enjoy running off an RPC. RPCs typically have wildly imbalanced voltages (even just a few volts makes a big difference), and the rectifier inside the VFD won't like that. You'd be better off just running a bigger VFD directly off single phase power.
J
jar944
Northern VA
Yeah, I'm in the shop right now trying a 20hp vfd on single phase. Certainly won't develop 15hp but if it works I'm out nothing other than swapping things around.
Edit.
Working well enough on a 20hp vfd on single phase.
