I am selling my VIAIR 400P air compressor. I bought it last year, used it twice (to try it out) and haven't used it since. It is like new and work great.
Asking $180 shipped, obo..
Specs: VIAIR 400P
Motor Voltage: 12v
Motor Type: Perm. Magnetic
Max Intermittent Pressure: 150PSI
Max Duty Cycle: 33% (15 on / 30 Off)
(Min On/Off @ 72F & 100PSI
Continuous Use @ 72F & 40PSI : 40 minutes
Max Restart Pressure: 200 PSI
Max Current Consumption: 30a
Fuse: 40a
Inline Pressure Gauge: 100 PSI
Auto Reset Thermal Protection : yes
The 400P can air up a 35" x 12.5" tire from 15 to 30 PSI in about 1.25 minutes, and air down the same tire from 30 to 15 PSI in about 2.75 minutes using the versatile 35 ft. air down hose.
This portable compressor is sealed for moisture & dust resistance, and it has a thermally protected motor.
Standard Features
Oil-Less Design
Hi-Performance PTFE Piston Ring
Stainless Steel Valves
Gear-Less Direct Drive Motor
Moisture & Dust Resistant
Anodized Aluminum Alloy Cylinder
Automatic Restart Termal Overload Protector
Mounting Plates with Vibration Insulators
Specs: VIAIR 400P
Motor Voltage: 12v
Fuse: 40a
Standard Features
Oil-Less Design
