I was hoping to get some advise/information. I recently bought a Rigid 15" drill press with a 1/2 hp 1Phase motor. This was a craigslist buy with several other tools in "the deal" and the drill press was the "nicest" item and looked to be in the best shape. I checked the obvious visual stuff (grabbed the chuck and shook it to see if the support bearings are shot in the quill, ran the quill up and down etc....) and it looked fine. I powered some of the other items on and they were fine. I didn't power the drill on. Shame on me.
When I got home I cleaned it up. The original owner didn't do a good job of removing all the cosmoline packing. There was still oil soaked paper between some of the parts. The chuck was so full of dryed out cosmoline it would barely open. I used 1/4 can of carb cleaner and a dozen shots of penetrating oil (pblaster brand) and solved that problem nicely.
When I powered it up, the machine made a 1-2 second shriek when initially starting , think squealing belt on a car. After it's up to speed, the press vibrates and the quill mechanism rattles from vibration, the belt housing buzzes like crazy. It's extremely loud.
I've used a few drill presses over the years, I've never seen one act like that. I am severely disappointed with only myself to blame. Terrified the press was garbage, I chucked up a new 3/8 bit and made a hole in some scrap MDF. The hole seemed extremely precise, zero play in it when sliding it back on the bit by hand.
This makes me think that the chuck/quill mechanism is fine, but the vibrations/noise are from the motor/drive train and will become a problem if left untreated (ruined bearings).
I only had a little time to fool with it because we were going out of town for the holidays. The wisdom of the internet is that belts can get formed around the pulleys and cause vibration. I'm not sure that is my problem here as these belts are multi-groove miniature serpentine type belts, not a regular "fan belt" style. They seem very flexible. They do hold a certain amount of their shape off the machine. The belt housing was showing a lot of debris that in retrospect is probably off the belts so I went ahead and ordered a new set of belts. After reading the owners manual there is an apparent setup step of leveling the tops of all the pulleys to get it in line. I figure that the original assembler didn't even get all the packing materials off, the probability of them aligning the pulleys is pretty small. I'll have to wait to get back home to validate that.
Unhooking the belt from the motor cured the shriek, didn't really change the vibration. I put my hand on the motor and it's vibrating like crazy. My 1/4HP Delta runs quietly with a minimal amount of vibration. The delta motor lightly vibrates if you put your hand right on it and that does not change if I un-hook it's belts. I did some reading and I'm hoping it's the fan or the pully that is out of balance on the Rigid.
If not, my first question is, If the motor itself is out of balance, should I:
a. Try and balance it myself (static balance on knife edges - redneck method)
b. Have it balanced by a motor shop($$?)
c. Just replace the motor with a quality TEFC unit.
I'm guessing for a $150-$200 motor that having it balanced is going to be as much as a new one costs. This motor looks identical to the 1/2 horse unit that Grizzly sells (H5374). That makes me think it came out of the same factory in china.
If I do try and balance it myself, how smooth should a 1Phase AC motor run? Could I even fix the problem? I don't have anything else with a similar induction motor, but I remember being around a lot of machines with similar motors that ran very smoothly... could be my memory though.... I've rebuilt many small electric motors (used to race RC cars) so I'm not afraid of disassembly/reassembly of the motor itself. I simply fear that balancing a motor without a machine is a waste of time.
If I do replace the motor, there are several brands like leeson, AO smith, GE, etc... Any of these better or worse for such an application? I know Baldor motors are fabulous but the cost is high. Looks like there is an appropriate leeson on amazon that is less than the above Grizzly. I think leeson has a better reputation than Grizzly..
Any input/advise you guys have would be greatly appreciated. If anyone else has dealt with similar issues that would especially be appreciated.
Thanks!
Thanks!
