Vim V214 dust cap puller
Granite80
Arizona
If someone has one of these, could you tell me the maximum dimension the jaws open up to?
I recently replace the CV boots on a 2006 4runner and destroyed the dust caps in the process of trying to get them off with a hammer and screwdriver, as the factory service manual recommends. So now I am looking for a good dust cap puller tool. The OD is about 5"
pacemade
Alaska
dust cap puller? When you get your screw driver under the cap did you twist it or pry it?
G
Granite80
Arizona
Tried both. Neither worked until I started hitting with a hammer. There was not enough lip on the dust cap to twist or pry
pacemade
Alaska
I'm not doubting such a tool, I will probably need one sooner or later. I just haven't seen one before.
pacemade
Alaska
I tap on it about an 1/8 inch from the edge on the cap and it should bow out enough to tap the screw driver in around the edge.
joecon
I used one like that and it worked pretty well
the one I have locks on I think it is a MAC.
