VIM wrench identification
C1070RS
Northern Illinois
I have a VIM 6 point wrench that has a long offset hex handle that has the letter E stamped on it in a couple places. No size anywhere on the tool. I've tried to find info on the web but with no luck. Thanks in advance!
C
C1070RS
Northern Illinois
If you're looking for more info on Vim Tool Company, which is still in operation, in spirit, sort of, through Vimtools - Durston Manufacturing, check out this GJ member four.cycle thread, linked here.
Thanks lugnutz, I looked over his Vim tool post prior to posting my request. Couldn't find a pic of a tool like the one I have.
I stated there wasn't a size stamped anywhere on the tool. Way too large of a wrench size to be a brake tool.
Perhaps if you took the time to measure the opening we would be able to make a more informed guess. Vim is a company sort of like a smaller version of K-D making specialty tools. They offer several distributor wrenches and drain plug wrenches as well as wrench holding racks, of which I have several. Your wrench could be used to access carb base nuts or other nuts located in restricted areas.
C
C1070RS
Northern Illinois
You got me there, Don!
The external hex size of the handle is 1/2" and the socket size is a 6 point 9/16". The overall length of the tool is 11".
I am pretty sure the company only sent 4.c some excerpts pertinent to his find. I was referring you to that post for the company information/background. Prior to 4.c's find, I don't think GJ had any knowledge of the connection. If I were you, I would try the same thing 4.c did. A formal, respectful, even ingratiating query with photos and dimensions. They may help you out just the same.
C
C1070RS
Northern Illinois
Sounds like a plan; thank you sir!
