Vintage 113.27520 table saw HELP
Pooleman
Va/Ca
I’m trying to replace the bearings on my table saw. I have removed the arbor from it’s housing and one bearing is off the shaft. The bearing nearest to the saw blade nut on the shaft has nothing left except the shaft bearing carrier (?) interior bearing support. There is not a retainer spring clip on this bearing, any help in removal of this race and installing a new bearing would be greatly appreciated. :bowdown:
ttpete
Dearborn, MI
You're going to have to get the flange off the shaft. It could be screwed on or pressed on. Then you can get the bearing race off using a small splitter with a puller or press.
P
Pooleman
Va/Ca
Ok,
I found out how to pull off the shaft, the bearing comes off the saw blade side with heat applied to the spacer(pencil pointed to in photo).
