Maui
I just picked up a vintage Boice Crane shaper earlier today. It is a surprisingly heavily built machine. Unfortunately it didn’t come with the fence or any cutters other than the one that is mounted on it. The owner said that his father purchased it new around 1950 or so, and used it for years in his cabinet shop. It came with a Walker Turner Driver Line motor. I wasn’t able to see it run before buying it since there was no plug and the wiring was questionable anyway. Once I got it home I pulled all of the wiring off of it and set it up to run on 110V. After lubricating the bearings (I suspect they hadn’t been lubricated in several decades) it seems to run quite well. On the motor tag it lists the horsepower rating as 1 hp, but the maximum current draw at 110V is listed as 15.2 amps. At that current, the power draw is 2.25 hp, not 1. I’m wondering if the current listed is the peak current rather than the continuous rms value. Any electricians out there able to field this question?
I can restore this machine to proper working condition pretty easily, but I’ve read that some people have converted machines like this to router tables instead of restoring them. Has anyone here done this type of conversion? Did it work well? Any opinions of whether or not to pursue that conversion instead of restoring it?
Maui
Maui
