Vintage Breaker bars that also were extensions
Neverfly
Arlington, TX
I know that the Plomb Wright Field wf-20 was a 3/8 breaker that had a female broach in the handle.
What other breakers sport this feature? I understand it was fairly common back in the day. Is there a Plomb 1/2 drive that had this, as well?
Any help appreciated.
ATC
VA
I have a "New Britain" like that...I'll update with a pic when I get home
Edit:
I thought I had a better picture. It's on the right-hand side:
toolslut6.0
Sk made a half inch drive and 3/8 one. Nice to have. Plus it turns an 18 inch breaker bar into a 28 inch breaker bar when you put a 10 inch extension in the handle.
drivesitfar
i just picked up an 18 incher that is half inch without any names on it so i'll post a picture when i get a chance to. would the Plvmb ones have their name on them?
rusty65
Pekin,IL
Yeah you can add a extensions in the handle for leverage but that's not what it was made for and it will damage the breaker bar and or the extension if pushed on with a solid tug.
Sent directly from the Snap On Kool Aid factory.
Wakefield
Arlington VA (but would like to get out to country
I think a long time ago most of the "hinge handles" had both the cross hole and the square drive hole in the end
both are for turning the bar while it is straight up like a long extension?
And makes a convenient hanging hole for a hook on a pegboard or wall
toolslut6.0
Your worrying too much.
BJ42LX
WNY
I have a 1937 vintage 18" Snap On breaker bar / extension. Unfortunately someone in the past 75 years broke the socket end of the bar.
I still use it regularly to break free tough nuts.
fourtythree
WV
I have an 18" Plomb that belonged to my great grandfather. It has the opening in the handle.
zkling
A Mac V18F is probably my favorite along side the HF24". The Mac has the female drive square in the handle. I can't recall ever using it.
N
Neverfly
Arlington, TX
Would the Plvmb ones have their name on them?
Yup. As far as I know (And there's a lot I do not know) Plomb was one of those manufacturers that did not go for unbranded tools. It may be because they were galled over the Plumb lawsuit...
Even when Plomb was contracted to make Craftsman tools, the tools were branded and named.
Williams
It had the 1/2 broach and cross hole
Thanks for the tip- I'll look into it.
Edit: J. H. Williams S40?
That's the hitch... I have no idea if I would use it. The problem with the Flex head is that it's not a U-Joint. If it flexes while in use, that could cause frustration.
Which may be why they fell out of favor... but, even so, I have a feeling I would use it. Even if I need to replace a detent or tighten a head.
Maybe I'm being "gimmicky" but it strikes me as useful to be able to 90 degree it, break the tension, then straighten the bar out and pop your speeder on.
rickhigginshtbr
Lower Bucks, PA
Pretty sure I have that SK in 1/4"
And a Plomb 1/2 as well as the rest of you.
Semi on topic, I have an SK 1/4" drive hard handled nut driver that could be used as an extension as well.
zkling
I've tried that. Doesn't work to well. Much easier to just pop the socket off the breaker and then snap a speeder on. Or what I prefer to do is just spin the breaker bar with my finger tips @ 180°. Now they did make speeder bars with flex heads like on a breaker bar. Those look like a useful combination.
monomach
Illinois
I have an Armstrong 1/2" like this. Part # S-40.
It even has another hole for a T-handle, complete with a detent ball in it.
Super Sport
West Michigan
I have an old SK 1/2" drive model. I didn't originally realize this was the purpose, and have used it several times with another breaker bar through the end of it. Sure enough, that led to it's failure when I loaned it to a friend to use it in that manner...
lbgradwell
Oakville, ON
I have at least two Plomb ratchets that are unmarked.
larry_g
oregon
I have a bit of a different one. It is a Duro-chrome 4481 that is MALE on both ends. 3/8" drive and the non-swivel end has a ball dent for a socket.
lg
no neat sig line
SMKS
USA, planet Earth
lg
no neat sig line
I wonder if it could have come from a set that included a ratchet similar to this?
Duro/Indestro churned out lots of these female-drive ratchets. I've come across quite a decent number of them in my area in the last several years.
I borrowed this photo from Alloy Artifacts.
https://home.comcast.net/~alloy-artifacts/duro-indestro.html
larry_g
oregon
back2class
I have two very nice ones. Made by Wright. Has the square female in the end of the handle. I think I have and SK like that as well. Nice stuff and I use them all the time. Not the extension part, but they are good breaker bars..not stubby beat up relics and a great design.
oak_park
Chicago
Here's a 3/8th Snap On. Odd twisted or offset head on the breaker bar.
N
Neverfly
Arlington, TX
Well... I have found a Bonney, SK and Wright all which have it. There's a Snap On F10-H6 like Oak Parks above listed currently on eBay.
Thanks for all the help.
The odd twist- I have noticed that most the older tools, pre-1940's have that. It was pretty much the standard that later changed to the straight male end- I don't know what caused the change.
So all of these I've found are 3/8ths... any 1/2 inch? Or am I just not finding them, but to keep looking under the same suggestions of SK, Herbrand and Wright?
N
Neverfly
Arlington, TX
Does anyone else want to go after this buckets contents with a wire brush?
Thanks to all for your answers. I have found, I believe, what I'm looking for. :)
N
Neverfly
Arlington, TX
I have the Plomb version, use it all the time.
Well, to update: I bought a Plomb 3/8 WF20 and another make for the 1/2 inch size.
I tested using them on the Jeep- just taking different nuts or bolts off in various locations that would need an extension- then putting them back on.
I was worried that the flex head that is NOT a universal would be an issue. Before buying, I contacted the sellers and asked if the heads were tight.
They were tight and I must say, the sellers were modest. The tools were better than I expected in condition.
In using them a bit in testing I've concluded that it works quite well and in many applications I can think of, looking over experiences in the past, I think I would prefer them over an extension.
An example: Those bolts that you break and they are hand loose for a moment, but then hit bad threads or heavy grime and get real tight on ya.
Break it, then straighten and spin it and when you get to the tight thread spot- pop the ratchet on and quickly work through it.
That's ONE example and this post is long enough, but I'm definitely glad I asked about this and tried it out, now.
tshusker
DFW, TX
Do your unmarked Plombs look like this? Mine sure looks like a Plomb, but no markings.
Mgdoug3
KY
I use a wire wheel on my bench grinder and steel wool, WD-40 and a drill for sockets. It is fun for me to bring back old tools. Even more fun to use them again.
