Vintage coats tire machine
MrRocket
Jefferson City, Mo.
So I picked up this old Coats tire machine and the hoses are bad and need to be replaced. Where can I go to get new hoses for it? The hoses are one piece with no hose clamps so I can’t just get some hose and replace it as the ends are crimped together. Could I get them from Oreillys? Thanks for your help.4863FB1E-0EAD-4842-A701-F8405F58E120.jpeg
Alienbaby17
Minnesota
One of the local Napa stores in my area custom makes hoses for applications like this. Might be worth checking if any of yours did and bringing them in for them to see.
At our shop we’ve had a company come out and make us hydraulic hoses for some of our hoists. They have a service van and build them on site.
MrRocket
Jefferson City, Mo.
Thank you, we have a Napa store here I’ll check on that. It would be nice if I could get a van to come to my house and make them.
don long
southern california
We have a company called hose man that will take walk ins and build me hoses while I wait. I'm sure with a little searching you can find a company like that where you live.
What is that 50's green car I'd guess a desoto or Gm product.
Alienbaby17
Minnesota
Car caught my eye as well. Looks like an early 50’s Oldsmobile based on the hubcaps. I have one in my stable as well.
man-a-fre
Nebraska
I got the same machine Coats 705 and love mine. Thought about rebuilding the air cylinder but was afraid of ruining the spiral lock ring that holds the ends on. Also on mine I got brass ******* from the auto parts store that threaded right into the cylinder on the top and bottom and put them on the foot pedal also, then used standard 3/8 air hose with hose clamps to hold the hose on barbed fitting instead of replacing the original hoses.. Use rawhide leather Ken tool aluminum wheel protector and you won't mar wheels at all Ken tool part no 31810. I also made an extension piece on my lathe to make the outer piece raise up higher for todays wider rims. Put a Ludwig speed king bass drum pedal on the foot control also
man-a-fre
Nebraska
I got the same machine Coats 705 and love mine. Thought about rebuilding the air cylinder but was afraid of ruining the spiral lock ring that holds the ends on. Also on mine I got brass ******* from the auto parts store that threaded right into the cylinder on the top and bottom and put them on the foot pedal also, then used standard 3/8 air hose with hose clamps to hold the hose on barbed fitting ,instead of replacing the rotten original hoses.. Use rawhide leather Ken tool aluminum wheel protector and you won't mar wheels at all Ken tool part no 31810. I also made an extension piece on my lathe to make the outer piece raise up higher for todays wider rims. Put a Ludwig speed king bass drum pedal on the foot control also
Hope this helps any questions fire away.
MrRocket
Jefferson City, Mo.
The car is a 1950 Oldsmobile 76. Good eye! What I’ve done on my tire machine is took a pair of side cutters and cut off the crimped ends to expose the ******* underneath then used hoses and clamps.
I’m very interested in the mods you made to your tire machine Man-a-fre. Could you post more pictures explaining what you’ve done to it please? I’d love to make mine more usable with wider and taller tire/wheels. Do you have any problems with aluminum wheels?
man-a-fre
Nebraska
No problem with aluminum rims , use the ken tool part 31810 or a like piece of rawhide leather as i I said and it works great doesnt scuff rims at all just did 4 2019 chevy silverado lt 4x4 truck tires replacement with aluminum rims no scuffs and those are real scuff and nick prone
MrRocket
Jefferson City, Mo.
Excellent! Can you post a pic of the piece you made on your lathe? Im really interested in how you adapted it and how it fits on your tire machine.
don long
southern california
I think that I have that same machine too. Mine is just sitting in storage waiting for me to find a place to put it for display.2017-01-12 14.48.53.jpg
