Vintage craftsman drillpress help needed
Jaclyn217
Pittsburgh,PA
I acquired a 1940s craftsman drill press. The chuck is totally frozen, can't be extended by more than an inch. I would love to restore and have it in working order it because it is an family heirloom. I can't find any info on what I need to do. Any suggestions would be much appreciated.
Rushton
Richmond, VA
First: Don't force it and don't pull on it any more. It is likely that the pinion gear to which the feed handles are connected have over-run the range of the quill. This suggestion is based on seeing that the stop collar has dropped down too low on the quill - a common occurrence. Pulling on the feed handles at this point will simply tear up the soft metal of the pinion gears.
Second: Read the information in the thread DWise has shared. That thread contains all the information you will need to disassemble, clean and restore this Craftsman Model 100 drill press. It will clean up very well if you're willing to invest the time.
Good luck with it!
454ragtop
Carver, MA
Almost looks like the quill lock might be engaged...……..
It's that little chrome lever on the left side just above the chuck, turn it counter clockwise, it should be loose unless you want the quill locked.
lafester
Northern CO
Oh man, half an atlas table lift. I hope the rest of it is there somewhere!
Almost looks like they were just using it as a collar lock.
Spray some penetrating oil on the shaft and it should work itself free. Then take it apart and give it a good cleaning. Oh and check the quill lock as suggested.
Pay close attention to FrankLee and read his epic thread.
