Vintage craftsman level, why double vials?
Marvin Berry
Northern NY
I'm going through all my tools to move them to my new garage, and I found this level that I must have gotten from my father in law at some point.
No clue how old it is, I assumed 60's Era.
My question is, why double vials? I can't find a rhyme or reason for this, at least the way this one is set up. For instance, laying horizontally the bottom vial is good, top one way off. Flip the level and I get the same readings from the opposite vials, bottom level, top off.
I'm usually pretty good at searching things up, but I can't figure this one out.
larry4406
Northern Virginia
Wild guess - typically the vials have have a slight arch to them. With yours, there is always an "up side" regardless of the way it is positioned?
blackdak8
KY
I think the vials have a slight curve to them and you use the one closest the the level surface you are referencing from.
bwringer
Indianapolis
Yep, I think this is it. The vials are very slightly arched, so you need two if you don't want to have to flip the level.
Why or whether arched vials are better, I dunno. Gotta be a levelologist around here somewhere.
MShaw
York, Pa.
If they are not arched the level won't work. The bubble goes to the high point of the arch. As the level tilts the high point changes.
Lesserstore
Texas
It seems that the vial question has been answered, but I can help with the date. It was made between late 1947 to early 1951. After that model was only available in 24."
Here's a 1948 fall Sears catalog listing:
And vials that are not visibly arched are custom ground internally. Either an early Starrett or Stanley catalog described the process, think it was called proofing or proving.
larry_g
oregon
A modern vial is barrel shaped so it will read correctly regardless of which side is up. A curved vial, like you have, will have an UP side and it has to be oriented so the up side of the curvature of the tube is the high point.
lg
no neat sig line
Toolmaker51
Missouri
Level-ologist?
Oooooh me, me me pick me!!
I'll be the levelolgist. in re: the Starrett brand, especially model #199Z.
Good levels are accurate. Accuracy range depends on intended use, but zero is zero. Here's how to check.
1) Somewhere, you have an area that is good smooth surface, and decent level; perfect isn't actually critical, kitchen countertop for example. Set it down, give it a couple seconds to settle, note the reading. Use 3 Post-its or 3 small strips of masking tape and put two on the counter along the levels edge, and one at the end. Pick level up, turn it around 180°, set it exactly same place (tape markers), allow it to settle. The reading must be the same, not important if level, but the same.
2) Get two pieces of wire, drill bits, straightened paper clip etc. Visually divide the level into thirds, set the wires in those locations, set the level back into position as close to tape markers possible, settle and turn it around. Again, the reading must be same.
What the wires accomplish, is removing 99.99% of what ever imperfections are present between level and the surface. A radical version could be a depressions or humps in level and surface that coincide.
You can see in any level, what a 1/16" or any dimension does to the bubble. A 1/16" will displace bubble a lot more on a 9" torpedo than a 4' framing level. If you level things accurately, this info is very handy.
Level a bench 12' long? Set the level down, parallel to length, of course it's way off. Use something small enough close to one end to zero bubble. I like using wood dowels, drill bits, depends on how far off.
If 1/8" gets zero, divide table length by level length and multiply the 1/8" that many times. If it happens to be a convenient amount, lets say a stack of washers, you'll be a little shocked how close the 'prediction' is.
When I level machinery, I've converted threads per inch of the jack screws into distance per revolution. Kind of a thrill to dial in with so little trouble, normally a tedious - hands and knees, up and down exercise you'll learn to avoid.
By the way, that Starrett 199Z? It's accurate to .0005 per foot; that's about 1/6th (one sixth) thickness of normal paper! It will react to drafts in the room, that cause contraction/ expansion. Leveling isn't magic or mysterious, but a lot of equipment enjoys being right.
