Vintage Delta Drill Press
tiggi
USA
I got my hands on a old floor model Delta drill press and I have started restoring it. So in the process I have been reading about the history of the drill press. One thing that I can't figure out is all the ones I"ve seen online have DP 220 head style where mine says DP 400. I am unable to find any more information on this type. Does anyone knows what model would this be?
zkling
It is a 11-12" or 14" machine? IIRC those were smaller than the DP220 (14") and overall model 645. :headscrat:
T
tiggi
USA
zkling
If it is a 14" machine, measuring 7" from the center of the chuck/spindle to the edge of the column then it is a DP220. Although the DP400 head was for 11" machines, so something is not matching up. Does it actually have DP400 cast into the head?
T
tiggi
USA
I thought I was 14" but you're right it is 11", I just measured it. And it has DP400 cast in the head.
Wm.Richardson
Tonawanda, NY
You can discuss your Delta dp further here: http://owwm.org/index.php
Choose between the wood working and metal working forums, they both get a lot of traffic. I'm sure that this dp has been discussed or that someone has one like it to help you. From your photo, I can see that it has a lot going for it, for example, it has the depth gauge and at least one knob to adjust the stop depth, it has the pulley guard complete with badge, it hasn't been painted and the quill lock handle is present. It also has the mortise attachment installed. I can't see much below the mortise bracket, do you have the drills/bits? Looks like a keeper to me.
T
tiggi
USA
Thanks for the advice. The drill is in very nice shape indeed. I didn't see anything missing or broken. The motor is running but in rough shape. I am working on restoring it. Drill came with mortising attachment, chisel, bit, guard, guide and some other whatchamaycallem parts.
Table had two small dimples from a bit but I've already fill those with my MIG and sanded them flat. They are barely visible now. After some cleaning and fresh coat of paint it will look as new.
T
tiggi
USA
I am finishing up the drill and the last piece left is the switch. I was trying to find something vintage that would match the era. I have a feeling that the switch might be too big compared to the drill head, what you guys think?
454ragtop
Carver, MA
Those switches look like momentary switches to run a mag starter, are they, and do you have a mag starter? Originally that would have used a basic toggle switch more than likely, often controlled by a steel push/pull rod. Or there is a common art deco 2 button maintained contact switch that was typically used on the larger drill presses, made by Cutler Hammer if I remember correct.
Jim
beltdrive
Smithfield, RI
I'm not sure which model this is that I just acquired a couple days ago...it has DP400 cast in the head...it has what I think is the 1930s patent number yellow label, and the 1/3 HP repulsion motor that I think is original. The thing is in great shape! I cleaned it up a little tonight and lubed it...runs great. Anyone know for sure what model or year it is from!? It is really heavy and the quality is kick-***....very clean example too. I gave 65.00 for it at the Colchester Connecticut swap meet (Allis Chalmers tractor show, tools, etc).
T
tiggi
USA
Nice find beltdrive. If I remember correctly they were putting those yellow tags with patent numbers during the WWII era. It definitely has the 40's look
Norcal
The tag is a pre Rockwell one, they bought Delta in 1945, picked up a 1939-40 Delta bandsaw w/ the same style.
