I have been somewhat looking for an older/vintage drill press, I seen this one, not to far away, anyone know about what would be a good price for this? asking $200
Thanks!
All original? Knock the guy or gal down as much as possible. It's worth good money, so try to get the best deal.
It doesn't have a "value". The owner or you (the potential purchaser) places a value on it. If you need a good floor model drill ... go for it. If you want to flip it, not a chance on this one probably.
Fair if no problems. I'd personally look for a little heavier machine.
See what sized pulleys it's got and the speed range. Lower speeds are a lot better for metal work.Is there anything else that I should or shouldnt be looking for (obvious) I am going to try and see this tomorrow.
Look at the motor name plate and check its horsepower.
For wood work, I really don't know what you "need" but I never ran into something myself that a 1/2 HP drill press wouldn't do.
For metal work, that same 1/2 HP drill press was a total pain to work with. It would bind & stall the motor all the time. Just isn't enough power for metal beyond thing sheet & small holes.
The 1.5 HP 17" drill press, on the other hand, punched a 3/8" hole (unpiloted) through 1/2" plate and never even slowed down. All I had to do was keep the bit cool & it just ate it right up.
So, it depends on your intentions but you should at least know what you are buying.
