Vintage electrical panel doohickey
J
jabberwoki
puyallup wa usa
Hard to get good pix it`s in a dark tight shed.
My mate took pix of the plate , ill post them when he sends them to me.
Looks like some kind of control panel to me?
wssix99
Chicago, IL
That's the last missing part I need... How much do you want for it?
Sinatra
It looks like a heavy duty variable power supply. Probably for test purposes. I think that component at the bottom with the hand wheel is a Variac. You can vary the voltage output by adjusting the dial.
Steve.S
Cincinnati, Ohio
Looks like a power supply for a turbo encabulator. If you can pick it up cheap, go for it! They've been getting harder to find lately. Check out one of the TC forums, particularly the wanted to buy sections. Someone always needs one for an encabulator that they've just picked up.
I'd take it off your hands but I sold my TC several years ago after the power supply gave up the ghost. Good to see another one on the market - hope it still works.
bbbarracuda
With all those switches and gauges you should be able to configure it to do whatever you want.
I'm leaning toward reanimating dead bodies.
mikedodge
Without seeing better pictures it sort of looks like an old training panel that you can hook up meters and motors and transformers etc to. Or some industrial test station for monitoring something.
foolishpride
Southwestern Ohio
It looks similar to the old relay test sets we used to use many years ago, but on a bigger scale. Multi-Amp was the manufacturer of those also. It's basically a Current & Voltage Source. I learned to test relays on an old Multi-Amp SR-51.
Chuckster in NJ
Hunterdon County NJ
That is a Multi Amp tester to check relays and circuit breakers. This "machine" will put put variable amperage across a breaker to test for operation along with how long the breaker takes to trip……. Notice the "stop clock" on the upper panel. I have used a multi amp machine (similar to this) to test over loads on starters, high voltage relays, circuit breakers.
Back in the late 1970’s I spent 8 weeks at the multi amp headquarters in Duncanville, Texas learning how to use their test equipment and calibrating high voltage relays.
This machine that the OP posted is a medium sized machine…… I have used some multi amp machines that are the size of two refrigerators and weigh 800 pounds.
BTW! The value of this ANTIQUE machine in the pics is worthless scrap and it would be almost impossible to find any one to buy it even for parts.
sliderhd
I wish you were closer. I'd pickup it up, set it in the pasture set it on fire and watch it burn!! I also have a lot of hours using the type of equipment calibrating protective relaying equipment. If you had some other pieces to go along with it you could calibrate your power meter!
