Vintage emergency ignition coil
454ragtop
Carver, MA
I had this thing for years, kind of bizarre, never saw anything like it. Anybody seen one, or better yet, used one? 6 volt, says it will start a car with defective points, how does it know when to fire?
454ragtop
Carver, MA
Couple more pics
driftpin
Well, it must be for cars of the 1940's-early 1950's, isn't that when they converted to 12 volt?
I think the points would need to at-least open and close for this to work. I don't know how a worn set of points which don't open would work.
I have some old products still in the box which I keep as mechanical curiosities. I like the artwork.
malibu101
Walnutport PA
I've never seen anything like this so I don't know, but.....
it might be a vibrating coil like on Model T's. That way it wouldn't need the input from the points to make a spark. ??
Movover
Central Maine
I am in agreement, it just sparks all the time and the timing is handled by the rotor and cap
DadsTools
Ah, the good ol' days, when duct tape and bailing wire would get you through many a repair and you could take half the car apart with a 1/2 x 9/16 DBE wrench.
Bill vonSteuben
Atlanta, NY 14808
In 1960-give or take a few-my Dad operated a service station. I had tossed a length of antennae wire in the back of the truck to take home. Dad took the truck on a service call-car stuck in the ditch. The car owner went along and wouldn't you know, didn't bring the keys! Dad hot wired the car, jumped the starter with a screwdriver and saved a trip back to town. When he got back he blessed me for putting the wire in the truck.
Couldn't do that today.
Ji m
The Northeast
I bet that coil will fire and run an engine,
but I wonder if it would be able to pull a lot of RPMs(?)
On another note,
I had my underhood wire harness catch fire and melt on an old Full Size Jeep pickup on the drive home from work.
Coasted into a parking lot,
disconnected the whole melted harness from the positive side of the battery,
connected the headlight and coil wires directly to the battery and (after a push start) drove the last 8 miles or so home.
No gauge lights, brake lights, alternator or anything else (I had the person I called to push start the heavy *** truck follow me very carefully so the brake lights weren't an issue).
If a wire harness goes up in smoke today the car is probably totaled :wtf:
