Vintage GE 1/2hp Motor
JZiggy
Atlanta
I picked up a nifty old General Electric Utility Motor. I'm curious if anyone has seen this one before or knows the approximate date of mfg.
It has one 5/8" output shaft, 1800 rpm. The motor is ball bearing (same 6203's as a Block grinder).
Also, I'm interested in replacing the capacitor as a matter of procedure, even though it seems to be working. I have seen block grinders and other small motors use a 210-260 mF cap -- do you think this would be appropriate here? I can't make heads or tails of the markings on the cap.
Roberts210
Missouri
I would take the capacitor to a good electrical supply place and ask them to match it. The place I go to can test them, and also come up with accurate matches.
Davefr
OR
I'd try 120 uF to start with. (same as similar spec'd motors)
But first, try and measure the old one as long as it works.
spongerich
Monroe, NY
I'd guess that she's from the 50's or 60's, mostly based on the modern font on the label, but that's really just a SWAG.
tym
I would advise caution if the shop is going to measure the capacitance of the old capacitor to select the value of a new one. Those older caps (the paper body would lead me to think 1950s) can have their actual capacitance values drift significantly as they age and the dielectric breaks down. I have had old (electrolytic) caps' values off by at least a factor of two in equipment a bit newer than that motor--and that was in a sensitive integrator circuit where the mfr would have spec'ed a tighter-tolerance component.
J
JZiggy
Atlanta
Thanks for the input, guys. I have seen a 210-260 mF cap in both my 1HP block grinder and in a 1/4hp Westinghouse motor. That's what is leading me to assume it may be suitable for a 1/2 hp general purpose motor like this.
