Vintage Hack Saw & Where to Get Blades?
redmed
I have this hack saw (or utility saw?) that I got from my father. This has been a handy little saw over the years, but now there is a split in the blade making it much less stable. I have been looking for a source for some new blades for it but so far have struck out. Anyone know of what brand of saw this is? More importantly where I can get some new blades for it?
lilredex
Toronto
They are usually referred to as Pistol Grip Hacksaws and they have fallen out of the popularity circuit. I have two similar ones, and have not seen blades for some time.
Currently, there are a couple of saws on Ebay for $5, it might be the best route until you find some at a garage sale etc. They are an actual hacksaw blade, not a wood cutting blade ( key hole).
R
redmed
I have thought of modifying a reciprocating saw blade but so far all have been just a tad too wide. Less than 1/4" that I could grind off. But then there is the tang at the rear of the blade. I would guess grinding would alter the temper of the blade. Not sure what would happen if I tried to snap off the tang.
R
redmed
I can't find anything like it on Ebay using "pistol grip hacksaw". If I found one with good blades I'd probably get it, but then again how can I tell good the blades are from pictures?
lilredex
Toronto
I found these and can check them out for you if you provide some dimensions.
Can send them to you or if you are close to Ontario, you could look.
http://www.rona.ca/en/replacement-blade-1422013
http://www.rona.ca/en/hacksaw---metal-hacksaw
http://www.rona.ca/webapp/wcs/store...=-1&latitude=42.3149367&longitude=-83.0363633
kvkmahesh1969
No you won't get a replacement from market but you can make your own from broken hacksaw blades.
Sent from my SM-G530H using Tapatalk
bb_max
central IA
I've got a couple of those. Always figured I could cut down a sawzall blade with a pair of tinsnips.
you know... I bought mine as a kit... after re-reading all this I'm not sure if it's a Stanley or not.... I needed it to cut ONE hole in something about 20 years ago. came with two (or three?) different blades, and I recall one of them was a pretty fine-tooth unit - suitable for cutting metal. I'd just poke around at a real hardware store that carries a good selection of tools and see if you can find a match.
because there's no consistency in the way Ebay sellers list things, the only way you'd find it there is by searching "saw" and that would return 9 million listings.
R
redmed
I would trim a sawzall diablo blade to fit using a dremel cutoff tool.
I'm going to try cutting down a Diablo sawzall blade if the Stanley or Kobalt keyhole saw blades are too large. I measured the blade and it is 18mm or 13/16" wide.
R
redmed
I pulled out the old pistol grip saw to cut a slot in a washing machine hose end that is seized on the faucet. Just before I started to cut I noticed the the blade had a split half way across the blade. Then I remembered why I had been looking for replacement blades for that saw. I did not want to start cutting the hose end and have the saw blade break while I was half done, so yesterday I went to HD to get a blade and could not find anything. I did pick up a Stanley Mini Hacksaw and today I started cutting with the Stanley. The blade came loose twice and was flexing on me. I grabbed the old pistol grip saw with the broken blade and finished the cut in nothing flat. I'm taking the Stanley back and definitely going to find or make a blade for the old saw.
R
redmed
I have just such a hardware store in mind, but it is a drive in a area I rarely go. I'm going to have to make a special trip. Sadly, the "real" hardware stores are getting fewer and fewer.
CJM8515
