I've decided we don't have nearly enough images of vintage jack stands on this site... So, post em if you got em. Here's a quick selection to get us going...
Here is a jack stand that a friend of mine has... He is looking for a mate to it.
Ryan,
Those look neat. How old?
Here are 3 of mine. Circa 1960s, maybe early 1970s. Inherited them from my Dad. They're great to use because they're light.
I remember seeing jack stands that were made from part of a rear end from a car or truck
Found this one over the summer, no idea of its age. It will just remain as rusty garage art.
My first pair were adjustable. Used one of those split axles as a base and schedule 80 black iron pipe as a center. I blew holes with a torch and used a worn out jack hammer bit as a pin. It adjusted from about 16" to around 20". I was 17 years old so safety was no concern. It worked for about 6 years.As do I.
Made from Ford rear ends, model a thru 48.
The side axle housings were removed from the center and cut to length.
I don't remember seeing any made to be adjustable, but it would seem plausible.
That type I typically ONLY use on small import cars. Anything else Id say is to heavy for them.
I've used these since the 70's at least. Probably originally my grandfathers. How old are these models? Would like to restore some time, they both still work fine, not sure why one handle is so much lower than the other.
Most of the ones I've seen don't have the square bottom platform, but it appears to be welded on, did the other rust away or is this something my grandfather might have added?
