Vintage SK tool box paint
MoboMac
Was wondering if anybody out there has found a match (or close) to the textured green paint on their old socket boxes....?
I have several that could use some help.
Pumpman1968
Upstate, NY
I believe the best suggestion I have read so far is to paint the "crinkle" finish black (no one has found it in the same color) and then match the paint over the black.
Durka
Howell, MI
Looks like a hammer paint or finish from here. I believe rustoleum makes it. They have green, not sure if it's the correct green.
Durka
Howell, MI
You could color chip it at a Sherwin Williams. One that deals with automotive paints. Pick out your color, -they can pack it in an aerosol can for you.
Steinmetz
Washington State
Agree. Do this. Sherwin Williams does formulate custom paints. They will only match to the color you have. Not to the color that was originally applied.
thundermug
usa
You may need to take the box to a place that mixes up specialty spray paint. It's not cheap, though.
ganymede
New England
Boxes from that era were wrinkle paint.
Easy to find that type but not in that color.
In the posted pic it doesn't look too bad.
I'd just clean it and leave it.
bonneyman
Desert SW
I re-did a tote box for my niece in a forrest green metallic. Not bad.
But that was a newer, Dresser Industries-era box - not a vintage sweetheart like what you've got.
Ralf11
bump to see if there is a paint answer yet
I have that exact same socket box...
Ralf11
Thx - I saw that but the idea of mixing a stain to go on top of the paint is too much for me. At least for an SK box...
I believe that the point of the post was that Lugz no longer needed to go through the stain process. In the example I posted above, I just masked off the intact original paint and sprayed in the area that was missing paint. I’ve used the paint on many S-K boxes with satisfactory results. Your results may vary.
That is correct. From now on, I will be using Midwest Military's TM9 'Signal Corps Type I' on every 1940's OD green box project, military or not, including Plomb, Snap-on, and S-K. I may still use some techniques for "aging", patina, etc. But it is the closest to 40's toolbox green I have ever seen in a commercial rattle can.
EDIT: There are all kids of techniques for wrinkling (a coat of enamel before a coat of oil-based paint; a hairdryer; and others), but I still think the easiest solution is a base coat of wrinkle paint, any dark solid color, fully cured, followed by a very light coat of your final rattle can color.
