Vintage Snap On analyzer
jkherd
Southwest Missouri
My son sent my Fathers Day gift a few days early. He is a Snap On dealer and happened across this the other day. Everything is there except for the manual but the search is on. The model # dates it to approx 1966 and is in great shape. :thumbup: Just what I needed was another toy for the toy box. LOL
Alienbaby17
Minnesota
I didn’t get into the field until the early 90’s. What exactly was this tool? Some sort of oscilloscope?
It was an excellent oscilloscope. Burn time, raster etc... i have used mine for years to check cars with distributors. Works great.
Alienbaby17
Minnesota
Wow! I’ve worked in a shop specializing in driveability for 25 years- I cant remember the last time I heard someone talk about, “raster”. That takes me WAY back.
I could actually use something like that from time to time.
joel63
Central FL
Don't forget parade.
firedudetl1
Rhode Island
grew up in the 60s/70s adjusting points and doing timing w/a timing light - never really learned how to use a scope on a car - so, what does it "do"
You can look at the ignition events in a parade (sequential) or raster (overlay) format to identify weak or misfiring cylinders on distributor ignition cars. The firing line spark and burn time can be read easily on these scopes.
firedudetl1
Rhode Island
so you can tell if the plug/wire is "bad" or if the cap has some kind of problem and isn't getting a good spark? Does it let you know if the timing is "off" as well"
thanks for the info - always knew there was good info off the "scope" but didn't know what it was
thanks again
rustyzman
Chicagoland
With experience, a good ignition scope can let you see issues with fuel mixture, full ignition circuit condition, deterioration of primary and secondary circuits and much more. It takes a bit of time and experience to learn to interpret all the subtle details in the pattern to catch some stuff. But basically everything that happens in the cylinder firing event is reflected in that pattern you see. You will see the coil charge before the event, the firing line as the spark gap is bridged, the burn across the gap of the plug during the spark and the oscillation of the remainder of the energy dissipating from the circuit after.
I have a great old Tektronix book that shows how to use their older scopes in industrial engines to identify worn internal components using transducers.
On modern DSO's, transducer and current probe use has become a very useful eye into many areas of vehicles that otherwise could require a huge amount of labor to see and diagnose. I have used many versions from old straight analog units to newer DSO's for diagnosis.
Oscilloscopes Rock.
Provincial
Near Salem, OR
I have a manual (two parts) for a Sperry Engine Analyzer for aircraft engine ignition systems. It is quite extensive and has lots of troubleshooting information. This is probably the leading edge of this technology.
