Vintage Snap On Box ID help
Chris321
I recently bought these two Snap On boxes.
Did Snap On stamp an ID code into these red label boxes as they did the later models? I’ve been looking with a flashlight but cannot find one.
I assume these are late 50s? I am planning a strip, clean and repaint and put to use in my shop.
Any info shared is much appreciated.
thehorse13
Jefferson County, WV
I have the same stack. Late 40s/early 50s is spot on.
I cleaned up the top box but left the bottom one alone for now. I will eventually restore the bottom box but if I had to do it all over again I would have just left the top box alone and left the stack in, "as found" condition.
C
Chris321
The Snap On dealer was even able to order keys at a very reasonable cost. I was going to paint but decided to just clean up and lube the slides and use as is. It has such nice quality and craftsmanship compared to what is available.
I removed the bottom drawer and found some early 50s Ford carburetor gaskets and jets crushed up against the back corner.
