Ryan
Administrator
Texas/Hawaii
I’ve been collecting and using vintage tire pressure gauges since I can remember really… Mostly because I just really appreciate their aesthetic and the way they feel in my hand. Age brings a tactile feel and a personality that the newer offerings just can’t match.
Recently, I’ve been asked quite a few times about their accuracy. When you find them, they are hardly ever broken but it’s rare to find one that is accurate. Thankfully, however, most of these 1950’s to 1980’s gauges feature a very similar mechanism and calibrating them is dead easy.
So, I decided to make a little video hoping to save a few more gauges. If you are into such a thing, check it out:
[embedyt]
Continue reading...
engineer2
Chicago burbs
On a Bourdon tube pressure gauge there are three things to consider: Zero, linearity (around mid scale), and span (pressure at the max reading).
First thing to do is get "as found" readings at 0%, 25%, 50%, 75% and 100% of full scale.
It's difficult to say what the claimed accuracy originally might have been. Typically 2-3-2% (low, mid, high end), but super cheap might be ±5% of full scale.
Cheap digital gauges typically claim ±0.5% or ±1% FS accuracy.
Any gauge used for calibration should be at least 4 times more accurate than the gauge being calibrated.
Since you Jaco gauge claims to be ±0.5%, it should be fine to check any ±2% gauge.
Accuracy specs apply at room temperature and error increases at high or low temperatures.
Most of the inexpensive round digital gauges you see are made by the same companies in China. I've found them to be accurate enough for passenger car tires. Caution: They are not designed for liquids.
Back to Bourdon tube gauges.
Span is adjusted as you have described in your video, but may vary depending on who made the gauge.
Zero is often done by pulling the needle off and pressing it back on so it reads zero. It's usually best to use a needle pulling tool to avoid damaging the axle/gear mechanism. On these inexpensive gauges it might be difficult to tweak linearity.
If you set your tires to 30-32 psig for example, the main concerns would be zero and best calibration at 30 to 32 psig.
R
Ryan
Administrator
Texas/Hawaii
Zero is often done by pulling the needle off and pressing it back on so it reads zero. It's usually best to use a needle pulling tool to avoid damaging the axle/gear mechanism. On these inexpensive gauge it might be difficult to tweak linearity.
You are an engineer. I can tell. I like that.
So my tire pressure gauges are generally used in the 22 to 42 pound range on passenger car tires. When I set up one of these vintage dials in the way explained above, I might have a .5 pound difference in that range between the vintage gauge and my modern digital... And that's perfectly fine with me... and certainly better than a pencil gauge.
mercifiknow
Somewhere I should be
I think I'm going to buy Bourdon's gauge. Terribly afraid of cheap imports from certain countries.
It's true...about the later...not the former. lol
Farmer J.
UK, Cornwall/Hertfordshire.
I check the accuracy of my gauge against the calibrated one in a professional tyre shop. It's local, and I know and trust them. Haven't needed to adjust my gauge, it's one of those circular old 'Made In USA' ones I got years ago and still reads correctly.
SteadyC
CA
Or going off a known "good" mark gauge + or - X and no internal adjustments are necessary(If within span of desired measurement). Just connect regulated air to a manifold and check all gauges and mark accordingly.
Sumboodie
AK
Most anything i have +- 20% wouldn't be a problem. More important that all 6 or 10 tires are close to equal pressure.
bbbarracuda
I never worry about how accurate any tire gauge is.
The important part is consistency.
Now, if the gauge reads 30 when it's actually 10.....
softailgarage
Bullhead City, Az.
I have that exact pressure gauge and have had it since High School, 44 years. Its always been kept in a glovebox and I have yet had any problem with it, but maybe I should re-calibrate to be sure.
engineer2
Chicago burbs
Use a tread depth gauge to check for wear across your tires. As long as it is even, you are good to go.
Edge wear = underinflation or lots of cornering like a maniac.
Center wear = overinflation.
Ricky Joe
Roanoke, Va.
Very nice video. I wish they were all concise and informative, rather than the flowery, painfully tedious ones that take so long to even start to get to the point.
Here is the only dial one that I have.
HoosierBuddy
Southern Indiana
When you get tired of playing with those little old gauges, you can always step up to the big leagues.
tool_scrounge
Southern California
i had a job in College working around pumps and I spent a lot of my time calibrating gauges for pump testing. The two gold standard methods then were:
1) Dead weight tester. Imaging an instrument with a sealed oil reservoir and a piston pressing on it. you placed calibrated weights on the piston to generate a known accurate pressure. You took a data at a bunch of different pressures and generated a correction curve for that gauge.
2) For lower pressure gauges, we used a mercury manometer. Super accurate but the EPA would probably stroke out now having a gallon of mercury in your laboratory.
CF74DF79-D18B-4FAE-9807-356777FF48ED.png.
bowbridge
Very nice! I looked at the price of that piece of equipment, costs around $12,000 !! I'll have to wait until Harbor Freight comes out with one.
tool_scrounge
Southern California
You can find them on eBay used starting at around $500.
I had one for years. It was a really nice art deco cast iron design. I finally decided to part with it. A younger guy enthusiastically buys it the minute the ad appeared. He told me it was going to be displayed as the centerpiece of his living room. I asked him if he was single. He was surprised and confirmed he was single. He then asked how I knew? Err… “Lucky guess!” I answered.
Mike'smeatshop
Were these old Schrader's designed to be calibrated?
Walkers
Cave Creek Az
Oh yeah! I spent years calibrating my gauges once a quarter when I worked at the gas utility co. You get to be a master at playing with Bourdon tubes and linkages. Still, every once in a while one goes in the scrap bin after an hour or two of not being able to dial it in.
ericg
I was wondering if anyone could tell me the correct orientation of the conical spring, the plastic washer and the rubber washer of my Milton gauge. In addition, the gauge will not hold the reading. As soon as the hose is removed from the tire valve, the pressure drops to zero. Is there an internal check valve that is not functioning correctly? Any help would be appreciated
Dragfluid
Pillager, MN
Many moons ago, I bought one exactly like what's in the Boss's pic up on top. Had it for years, then I don't know what happened to it. :(
Vtor
Left Side of the Moon
I have accu cage like OP, but white face and it also suffers from being too suffers from being 2-4 psi off at around 30psi, but if that is all you use for balancing front/rear pressure during competition.. its OK.
Was gifted a longacre w broken glass few years ago that i restored, so that's my go to now. I do miss the super compact nature of the accu-cage. Tuck in seat cushion.. off to the next run.
Jim Sperry
S.E. Pennsylvania
Beautiful to see their gauges still used. I used to have the calibration chart from Philip Parduhn at ghmeiser but it is no longer findable :unsure:
GarageDan
I never knew how to calibrate these, thanks for sharing! Now... you say you had 20 of these in your collection... you can't say that and not share some pics!
GarageDan
By the way, you probably drove the price of these up. lol. They're pretty pricey on eBay now.
