As far as I know that's a pretty generic little drill press made under lots of names, and new models can be found for under $100. I've had two like it, one branded Master Mechanic that looked extremely similar, which I sold when I found the other, a Craftsman, because the Craftsman power switch is in the front, ie right in my face, which I really prefer vs having it on the side. I'm not a pro so for my basic needs (mostly drilling into wood, occasionally using sanding drums for tight inside curves) and limited space they both did the job, and I was happy with finding each used but clean for $40.
I'd say make $40 your highest offer, but depending on your needs I'm sure many people here would suggest being patient and for a little more money you might be able to find a much more capable (older, heavier) drill press. FWIW I also came across a Tradesman scroll saw once... it worked okay, but definitely nothing spectacular, I think it had trouble keeping the blade under tension.
Hope that helps, good luck with your hunt!
