Vintage Xcelite or other Nut Driver Sets
Or, alternatively, you can hold the device in the right hand and use the left hand to re-adjust the aluminum foil wrapped around the rabbit ears. :thumbup:
Harry Oh
western ohio
I recently came across a nutdriver of sorts. No makers name just a part or model #. The nut driver is 7/16 and the hex is 1/8. I'm assuming it is made to adjust something with a locking nut. Any ideas on use or application? 20220321_084440.jpg20220321_084535.jpg20220321_085526.jpg
JjKk40
New York
Here is an early Xcelite 1/4” driver I grabbed off of eBay recently.
-Don54312328-EF92-46ED-9038-AA51041903CB.jpegB8ADE71D-8F19-4EA5-B57C-590CB62B1E56.jpeg
Nicl 2A qgrab Don! I threw one of the older Xcellite drivers into my wartime Duro ignition wrench set until i, or If I find the correct one.
D
I put a bit of Brake cleaner on a paper towel and wipe quickly to remove the greasy deposits before the plastic melts. It evaporates so quickly it doesn’t really damage the grips, just leaves them clean. I do it all the time.
CoogarXR
Nice. I have a set of yellow Vaco pliers that are stained brown that I have tried lots of chemicals on, and nothing so far has brightened them up. I'll have to give brake cleaner a try. Somebody also suggested gojo hand cleaner, but I don't have any of that on-hand (no pun intended).
CoogarXR
I snapped up this set of Xcelite metric drivers today at the flea for the grand sun of $0.50. Missing the driver handle, but I’ll let the next owner worry about that!
Just an FYI, it's a common mistake to assume that is a metric set. In the era of those tools, Xcelite didn't make a metric set (they made metric sets later though). The numbers above the bits are the number of 32nds. So the "10" isn't a 10mm, it's 10/32 or 5/16. The "8" is 8/32 or 1/4, etc. $0.50 is a sweet "you ****" price on that set too, lol.
Odd Job
British Colombia
Picked up the cast iron Spintite holder 5 or 6 years back at the flea market, still attempting to fill it. Looks good on the shelf. Have the Xcelites in service, thier wall caddy remains illusive.
CoogarXR
And while it is a 99PR, it's older than the one in the catalog. They made the 99PR forever, and it's been through several revisions. If you notice the one in the catalog has 4 slots in the roll for 4 standard 99-series screwdriver blades (2 slotted and 2 philips). The older set pictured above has 2 slots on the right ride of the handle pouch for two double-sided blades like these:
Those long double-sided blades can be difficult to find. Also, another side note, the handle would be like the one I am showing here too. Darker orange than the handles of today, and almost a flat top. Modern handles are much more rounded.
Welp, that's today's Xcelite trivia, lol.
D
I’m now on the lookout for the handle and the two combination blades, having received Username’s nice set in a care package. I may have a couple of handles that will work as substitutes but am watching for the exact tools above.
-Don2C71BAA1-3F36-4913-B8E5-BA851A669B90.jpegE2094AFB-B847-453F-92CB-6AD2AE35EE06.jpeg3C2F9459-84D8-444F-9B22-C525F2C1712B.jpeg76567DFB-C2FE-4670-98C5-56B796E68AFE.jpeg
MisterEd
Florida
A well used set; Park Metalware Xcelite Nut Drivers x5; Nos. 11, 9, 8, 7 and 6.
I'm guessing these pre-date color-coded handles?
D
I like those early ones. I believe that they offered both handles with the different colors or all the same color like yours concurrently. I have both styles. It seems like the different color handles became more popular early on.
Yellow handle 1/4” driver.CE1A8D4B-5306-413D-9A20-9E0F982E2AEF.jpegC88D68FA-F35D-43B1-8D05-9C90BB99841D.jpeg
Both choices offered in the 1942 catalog. 34A1E0C5-9EAD-4057-B40F-8DA38E65BDDB.png4A254D0B-9BCB-44E4-9C7B-84090A0C0416.png
MisterEd
Florida
You have a better grip on the handles than I.
After reading a bunch of disparaging words about Nut Drivers I figured some well used ones were needed for balance.
D
There was some discussion about Park Metalware/Xcelite possible patent information on their nutdrivers after LesserSon found a 1/4” nutdriver marked Patent Applied For. After some checking, I was unable to find their patent. I did find a few early ads though. My early rack is marked Patents Applied For as well.17B07C3A-1FB2-47A2-B20A-7F3157D7DC0F.jpeg4D0EC032-F2A7-4041-B345-B09AD88E0A6B.jpegD476C866-848A-4078-9734-903B1EF99232.jpeg49A21AC0-2570-4B74-8C66-1560E8B4B36C.jpegB0CDDA01-520F-4B95-9A52-3791DAA528C4.jpeg
I've never found any patent, Zilliox, Petre, or other, for Park Metalware nut drivers with the XceLite brand, but if you look inside the 1942 catalog, that's clearly when they first introduced the concept of different colored handles, one for each size, and gave them the DeLux suffix. LS appears to have found an example. The 1944 ads don't use the DeLux term, but they do re-use the terminology from the 1942 catalog ("new", "truly different", and "unique") that would be a necessary requirement for qualifying them as novel with the USPTO. If you look at the top of page 25 (which I see you've handily posted in post #300), you can see that they placed a little "PAT. APPLIED FOR" notice deliberately and directly under only the fancified "With Colored Handles" part of the "XceLite Nut Drivers With Colored Handles" title on that page. All of this points to them applying for a patent for the colored handles in the 1941-1942 timeframe.
We have to accept the possibility that the reason it can't be found is it never having been granted. The USPTO may have found the idea beyond unique and beyond patentable. If so, I have to say I can see their point.
What's interesting and potentially very informative about your rack is that it's not early. That was not made by the Park Metalware Co, it was made by the XceLite Inc., which means it's from 1952 or later. The 1944 ads extol the "unique" security virtues of the rack, called a "Handy Lockable Toolholder" on page 26 of the 1942 catalog, and sure enough, deliberately and directly under that term is a smaller "PAT. APPLIED FOR." notice.
In 1952, the company now known as Xcelite, Inc. was apparently still waiting for a patent to be granted for the rack.
Methinks Park Metalware applied for two different patents, one for the colored handles concept and one for the lockable rack, at the same time.
Oddly, I have not seen a patent for the rack, either, despite it seemingly being more patentable than colored handles.
De Lux Multi-Purpose Set No 99
Metal latch on right.
Swings open on hinges.
I found something you may find very interesting while poking around in Park Metalware Patent Research Land!
DATAMP is not aware that your awesome box was ever produced. This is not that unusual. It's more or less a forum-less version of GJ's hand tools research "staffed", like GJ, by dedicated volunteers. It was patented (2,487,174) by John N. Petre and assigned to Park Metalware on November 8, 1949. Link to its DATAMP page is here. It's a boring page because they have no photos of one, and because they have no photos of one, they didn't bother to post a photo of the Patent Diagram, either. But if you click on the little "pdf" hyperlink under the big white 'No Image Available' square, or just click here, you will see a patent drawing of your box!
Better yet, if you send them your photos, when collectors like us go to that page in the future, a photo of YOUR BOX will appear there! :)
I picked up two more for the "or Other Nut Driver" category at the flea market yesterday, gents. All thoughts welcome, because I am stumped and my Google-fu is on the fritz on these.
The first is a handsome antique ND with a 3/16" hex opening with dark natural steel ferrule and socket and a black-painted wood handle. I have looked at it too often to see anything other than "JAN. 1936" and "M.T.(iIlegible)" or "M.F.(illegible)" in those rad inked markings. Millers Falls? Milwaukee Tool and Forge?
I have never seen anything quite like this one before, but I love it. The handle (hard composite) is nearly 8" OAL. That bit with split-spring male tang has a 5/16" hex opening. It's shoulder is a 1/2" nut that fits inside the 1/2" opening in the driver, that also functions, of course, as a 1/2" hex nut driver. I'm supposing it may have come with other bits. Searching for a company with the name "The States Company" was problematic, even with the help of the Hartford. If it had a S/N, they never recorded it.
I looked thru some Millers Falls catalogs around 1936, didn’t see any nut drivers.
Also found The States Company in Hanford, seemed like a power company, so wonder if those were made for them, rather than for retail sale.
At a glance, it looks like a Hallowell design. The handle, not the bit adapter.
D
On Saturday I found a Silverbrook MFG. CO. Sock-O-Matic multi nutdriver. The spring loaded sockets were kind of rusty but an overnight in evaporust freed them up. I found several listed on eBay at rather low prices but I had never seen one before.
-DonF5DC8006-C784-45B2-ACC0-D4BF46B73A69.jpeg559798A2-AB24-48BE-91AA-D4C6DA61DF4B.jpeg4B427A89-8C4C-4823-8CDC-E943796CF097.jpeg
steel 35
Between the PNW and the Emerald Triangle
D
In order to complete the set, I picked up these pieces on eBay. The evaporust helped some but some of the tools have permanent damage to the finish.
-Don18A07713-4C1B-468B-A2DD-31679B55A807.jpegB4E2BCFF-D768-47EB-8518-4010D1BB4C45.jpeg1A2F2BA2-2018-4744-B1B6-5725A961256A.jpeg
Mintgrun
Kingston, Wa.
Here's an aluminum driver with a hollow handle that holds sockets inside. There aren't any markings that I can see.
When I found this tool yesterday, the cap for the handle was held in place with some gummy old duct tape and when I removed it I saw that the end was mangled, so the cap would not spin in.
I found a deep socket that fit the inside pretty well and clamped that in a vise with one end sticking out, to use as an anvil while I tapped the flared parts back to round with a combination of hammers made of wood/plastic and finally brass. Then I put it in the lathe and trimmed a tiny bit off of the end to true it up and used a boring bar to remove the first few threads, since they'd been cross threaded. Now the cap fits well again. That was a fun one to fix.
The tip is hollow. I'm guessing that is for the end of long screws.
I think that might be all the sockets it came with, because the stack pretty much fills the handle.
I wish I could show the repair to the person that taped the end in place and thank them for keeping all of the parts and pieces together.
Tom
D
I was finally able to unite the correct pieces with my early 99PR that Username gifted me.F945B992-8DC9-4E1C-9EF0-0EBDAD0F4EA0.jpeg
CoogarXR
I know this isn't a nut driver, but I wanna celebrate somewhere doggonit, lol. I finally found the last of my Xcelite Scrulox drivers, the SL-3 that I have been looking for forever. It's in "pretty used" condition, but I'll take it. Normally I hold out for excellent condition drivers, but this one was super-hard to find.
And finally reunited with the rest of the lineup:
