Vinyl plank flooring **** joints
akpolaris
Seward, Ak
I recently saw a tiktok video of a technique to secure vinyl planking **** joints. I believe the poster used a bead of silicon between a joint that was spreading and pushed the joint back together and wiped the bead clean. It looked like a practical solution to a fairly common problem. Is anybody familiar with this practice?
PCustoms
VT
wow 112 views and nobody has an opinion ??
I've yet to see properly installed flooring pull apart at the **** joints. I have over 40' length layed continuous and around corners, all with proper expansion gaps, and nothing has pulled apart.
I suppose glue may work, but it's a bandaid covering a symptom of another issue.
rlitman
Long Island
Vinyl flooring can be kind of brittle. Carefully assembling long seams together by hinging them into place should preserve the integrity of the long locking end, but I've seen a lot of short ends snap when hammered together (and there isn't a much better way to assemble them). It's a very big issue if hammered on when cold (where the flooring is both more brittle AND contracted), but not as much of an issue when the floor is warmed up to room temperature ahead of time.
So, if the short click ends to end up cracking, you don't have much of a choice to keep things together other than adhesive. That being said, I think I'd use a clear PVA like Weld-Bond before I used silicone. You want something that can flow into and fuse the crack, and maintain real structural integrity. Neither of those are something silicone excels at. A water based construction adhesive such as Loctite Power Grab would be an ok alternative.
PCustoms
VT
Pva peels right off, I've dripped tight bond on it a few times.
rlitman
Long Island
I've edited my post, but am standing by PVA. Peel strength isn't as important as shear strength when used within the seam. PVA was the gold standard for floating floor connections before click systems came out, and is still perfectly compatible with click joints for additional (though generally unneeded) support.
Anyway, PVA peeling off just means that cleanup, in case you missed some drips, is easy. Silicone is a royal pain to clean, wet or dried.
