Vinyl weight limit stickers
NUTTSGT
Northern Central Ohio
Something's wrong with your label maker........it misspelled toluene LOL!!!!!
Nutts needs to buy a better label maker that has speel chek. ;)
I won't disagree... I was busy doing a few things on a time limit when I remembered to try this "wipe" test.
Honestly, I do want a different label maker....one with a qwerty keyboard rather than an abcde style keyboard.... PITA.
OccupantRJ
Eastern North Carolina
Why even use labels ? If it bends, it’s too heavy. If it doesn’t lift it, it’s too heavy. If it tips over, it’s too heavy.
If you want to get fancy buy a sharpie 👍
In true GJ style, a dial indicator must be mounted to measure boom flex, then a load chart generated as a label to be attached for flex vs. safe load comparison. A pressure transducer with digital readout must also be attached to the boom hydraulic cylinder along with an onboard lithium battery and charger and have wifi output to your smart watch, which generate audible overload alerts. Or mark it with a broad ink marker if you are one to settle.
