ViperMig Welder $445 shipped
Gamble
CHITOWN
ViperMig Welder $534 shipped
Some of you know I'm a dealer for Razorweld. They have been around for 30+ years and fairly new to the US market. I've tested and I owe a lot of the products and I love them. So I am throwing them on sale in favor of your thoughts/opinions and reviews. Leave them on a forum for people to find, my website, amazon etc.
If anyone is local to Chicago and wants to try it out first hand you are more than welcome to come by and try it. I also have the 200amp ac/dc tig setup & the 195amp Razorweld mig welder.
I'll be running this sale until they sell out.
Vipermig 180 with inverter technology.
180 amps
Dual voltage. Pigtail adapter included
Euro Connect gun with 10' lead. Binzel style consumables
Flowmeter & Gas hose included
Back burn control.
Cast aluminum wire feed assembly
30% duty cycle at 180amps
Holds a 10lb spool
Will stick weld. Comes with stinger
1 year warranty on power source
Can be purchased on my site
http://www.gamblegarage.com/index.php?route=product/product&path=108&product_id=141
And additional pictures can be found on amazon
https://www.amazon.com/dp/B01GWMT4M4/?tag=atomicindus08-20
G
Gamble
CHITOWN
What are the dimensions of this unit? Also how much does it weigh?
Just went out to measure it so they are roughly
19.5" deep
8" wide
14" tall (including handle)
Actual weight, I'm not sure at the moment. Have to go get a scale. The shipping weight was 54 pounds. The unit is pretty light. I'd venture to say around 35 pounds but I'll let you know for sure later
Could I use this to weld somewhere around 1/2" plate steel?
Sure you 'can' weld it but it's probably not ideal. I would want at least 250amps for doing something that thick.
bagged150
Waldorf, MD
19.5" deep
8" wide
Awesome thank you. It would need to be a powerful welder since I will be welding on my front suspension when I put the new air setup on. Should I use a gas welder or would a one like this work fine? Could you recommend some names to look at, none that are named Miller or Lincoln.
G
Gamble
CHITOWN
The viper series is entry level stuff, what you're doing isn't exactly entry level lol
If I had to buy a welder, I think the Razorweld210 would be a good choice.
It lists for $1000. check your inbox for price
I'd also use a flux or dual shield flux wire.
details here
http://www.razorweld.com/catalogue_product.asp?product=986&category=21&subcategory=85
If you need more power the 250amp has a lot of balls
Details: http://www.razorweld.com/catalogue_product.asp?product=988&category=21&subcategory=85
Price is 1675
Forum member price would be good. Thats freight included (not lift gate service which is extra)
Car_Guy
Arizona
Do you really need 1/2" thick steel for your front suspension? that seems much thicker than you need. 3/16 should be good, maybe 1/4 if you really want it beefy
bagged150
Waldorf, MD
I'm actually just guessing. I will have to measure it tomorrow. Here is I pic of you can kinda tell from this. It's from Michigan metal works.
fd0ed4ddf1e595e4d237c7ceafd906c1.jpg26b0742eabd31342763d237286c17578.jpg8bb37bbb06801f931dbbf35776ea9f8f.jpg
Car_Guy
Arizona
Fair enough, I was not expecting you to be making control arms, i was expecting some brackets. Those are going to be high stress welds, I recommend that those are done by a professional welder.
Design wise I am not a big fan, those look really heavy for the strength, tube would be a much better choice, it could have the same or better bending resistance for less weight.
But sorry to derail a welder deal thread
Farmall450
Marengo, Illinois
I feel if you're asking questions like this on here, Car Guy is right.
The weld will be the weakest part on those monsters most likely. Have the guy that tigged it in the picture do yours. :rocker:
bagged150
Waldorf, MD
Oh yeah I am definitely using someone who knows what they are doing. Since I have a Ford, there aren't many options to go with line a Chevy.
bagged150
Waldorf, MD
The guy that tagged it is a company in Michigan. He can't exactly come to my house and put everything on and we'll it for me. I'm just buying the welder and a buddy will come weld it for me. He had a welder but it may or may not be strong enough and it's at his work.
2002maniac
Utah
If the quality is similar to my Chinese AHP tig welder this is a bargain!
Gamble, how does Razorweld's QA, repair, and customer service compare to AHP in your experience?
G
Gamble
CHITOWN
I think the quality is higher because jasic owns their own factory. They build it to their specs and from what I have seen they really do a nice job of everything. All bolts are tight, all connections sealed from vibrating loose, plenty of foam in packaging. All the standoffs I have seen so far for daughter boards are metal. Some boards will interlock to another board for more stability. They have their stuff together.
I try to take care of any and all questions for my customers. If I can't I will reach out to Razorweld and find them. Or everyone is welcome to call Razor themselves for questions. They are very knowledgeable.
