Red Green
I would check pawn shops and local(small) hardware stores and see if they have any new old stock. Those that you took a pic of look like the cheap ones I have from HF.
have you tried clamping the end of the cheap ones in a vise and forcing it?
i don't think you can hurt them any worse than they allready are
Hmm. Maybe I shouldn't show you Irwin's new labels then...
The thing is, the curve goes away if I tighten the clamp with death-grip clenching power. I pop them open and the curve returns. I don't think my cheapo vise can straighten them without damaging something.+1 on that idea. Open them up and put one side at a time in a vice to strighten. It will work fine.
These were made in Taiwan with a "to Irwin specifications" clause. I've started seeing the "global components" on other Irwin products though.I never liked the release lever design on them anyway.
Kind of. That was my themal physics text. I was brushing up on something when the second pair of vise grips were delivered, but immediately whipped out the camera in case I wanted to send the tools back later that day. Then I decided that the white pages provided good contrast to highlight the jaw gaps.Stuey, is that a P Chem book in the picture with the Vise Grips?
Coach
so I'll see. Would be well worth it to buy a couple of them to have around and pass down later on in life when all that is around is the new ****
Then there's my belief that name brand tools with an extra premium should work flawlessly immediately.
Point taken..... Find someone with a better vice and give it a try. You can't screw them up more that they are. Now they are worthless to you. If you separate the pliers and add a nut on each end, on the opposite side put a nut in the center to help spring the center in. (Your Micky Mouse vice may handle this)
if people will buy **** pliers why not **** taps and dies.
They do! They see it done on TV. A tap is a tap. Then they learn how hard it is to get a $.50 tap out of a $$$$part! The people with the 1" thick skull will attempt this feat several times.
If they are lucky, among the new curse words they learn... EDM then ACE, Greenfield, Tilex etal.
Well, I already sent back all three curved pairs to the distributor. I really don't have the time to try to get the tool to work as was supposed to. I'll just pick up a pair of seamers next time, or a different brand of the locking style. Your advice does make sense though - I might try that next time I encounter a similar problem.You can't screw them up more that they are. Now they are worthless to you. If you separate the pliers and add a nut on each end, on the opposite side put a nut in the center to help spring the center in. (Your Micky Mouse vice may handle this)
Well canadian tire has these on sale for 12.88 going to go look at them tomorrow hope they are old stock and not the new type will buy two set's if they are the good ones (made in USA) say's on the pack USA lol also say's home and hobbyso I'll see. Would be well worth it to buy a couple of them to have around and pass down later on in life when all that is around is the new ****
Perhaps y'all can tell from the pic? Thanks willing to pick up a couple pairs and ship to you guy's who want a good deal if they are real vise-grips![]()
Are you sure? They gouged my sheets, had varying degrees of curvature, and well, gouged my sheets!! I've seen some seamers with slightly curved jaws, but their jaws were much softer and didn't mar the alum sheets they were used with.Elroy has news for ya; These vice grips are made that way. Yep on purpose they are curved. It's not crappy quality control. They are made that way.
Look at this way. At least the blades are tempered and not soft.
Are you sure?(
you makin' fun of the shape of my head?????![]()
Nope, don't know anybody that welds. Before I returned the tools, I considered using flat stock to protect the sheet from the jaws. BUT, I then considered that if I turn it into a hacked tool, I may as well just use two regular staight-jawed locking pliers with flat stock shims.Stuey My brain just had a power surge. What about 2 pieces of flat stock 1X2 and weld them to the pliers ?
Don't tell me you don't know anyone who welds. However IF that is the case. IMO you need to get some better/crafter friends.
We found them and they all said made in usa with global components and did not have made in usa stamped in the handle. I pointed out the difference on the package and said those are made in taiwan she looked and said she could tell a difference in the two and said something about rooting threw the bin and store room for more lol I guess she was surprised that they were not being made here anymore
