I'm trying to take this vise apart, but am having problems removing the nut. I'm assuming this pin needs to come out somehow, but I've had no luck with it. Can anyone help me out?
Knock it out from the bottom with a pin punch and a deadblow hammer. It might take a few hard hits, but it'll move. I just did the same thing with my Parker.
Is your vise a Prentiss? It looks like a No.56 and mine has an access hole in the bottom. They will get covered with grime/rust/grease so it will need to be uncovered before it can be removed.
Some of my Athol's have a pin with a collar so they can be taken out from the top is there is enough room to fit a prybar underneath them.
If you still don't "see" a hole, take a measurement from the top side and transfer that to the underside. Use a small drift, big hammer and pray before you hit.
