Tejaas
Ok so here is the deal.
I happened across another older vise, this one a swivelbase Yost #204, I believe. Manufactured in Holland, Michigan - It has the older (?) flared/flatted handle ends.
This vise is rusty, but the castings are in pristine condition - the jaws line up tight and square, etc... However it has a somewhat bent handle, and as it turns out the ACME screw is kinked.
It is kinked, as in she will not turn more than a 1/2 turn in either direction. I'm talking extreme binding in the guidenut. I can SEE the rod wobble, and I'm positive it IS NOT rusted/fouled/seized due to corrosion or the like.
I am $30 into it, and for $110 more I can order a brand new Screw/Handle "kit" directly from Yost.
I would have to literally cut the old threaded rod out of the vise to disassemble it, but that's easy enough.
I like the idea of a shiny new and straight ball-ended handle, new guide, and screw paired with the original old castings... But would $140 total investment be able to be recouped should I ever decide to part ways with it...?
What would you do?
Here's a few hasty photos of the vise in question, as well as the Yost "Repair Kit".
~Tejaas~
What would you do?
~Tejaas~
