Wacker Compactor
gdocktor3
Connecticut
A buddy of mine gave me a Wacker that was submerged under water. It originally came with a 5.5 horse Honda motor. Obviously it's shot. I have an 8 hp Brigg's motor that I was thinking about putting on it. As long as everything lines up with the the belt and what not, does anyone see a reason why this wouldn't work? If a 5.5 hp motor turns (x)RPM at wot and the 8hp turns the same at 1/2 throttle, everything should be peachy, right? Or will I end up destroying something? I haven't looked into it much yet as I just picked it up last night.
B_Bimmer
Eastern Iowa
Quoted for the record.
Virtually all small industrial engines are governed for the same max RPM.
bob15
Northeasten, CT
Have you tried starting the Honda (after giving it a small cleaning)? I have had several small engines (and one Kawi snowmobile engine) be totally submerged by water and got them to run fine again.
4x4gearhead
New Hampshire
Is the compactor old? You may find that 8 hp engine might be too much for the eccentric, but if it were me I would probably try it as long as I didn't have to Rube Goldberg the thing together. My father has an old Beckett I think that I am going to try to throw a 6hp engine I have on to replace the 4.5 hp Honda.
earlthegoat2
SE GA
Do the two engines have the same size and length of output shaft and the same coupling method?
G
gdocktor3
Connecticut
I literally picked it up last night. Haven't done anything. Only reason I grabbed it is because I have the Briggs. Both are horizontal shaft. The Honda is locked up and my buddy soaked the cylinder with Marvel, but it hasn't budged.
Mhyde52
Averill Park, NY
Possible, but unlikely that everything lines up right for that 8hp briggs. Probably best to grab a $100 HF engine that will line up right, and have yourself a nice plate compactor for cheap.
L.Cheapo
8hp engines usually have a larger bolt pattern for mounting. If you can solve that, it should work. It would be wise to research the RPM of the original engine. Most small 4 cycle engines are governed to 3600RPM, a small number 4000. But they can always be reduced by the mfr of the equipment, and often are. This is achieved by adjusting screw stops or even different strength springs, often identified by color. Wacker made some quality equipment, and it is possible they spec'd a different RPM due to the nature of the machine and the desired effect. If you can make the engine physically fit and set the RPM correctly, I don't see why it wouldn't work.
whyNick?
Midwest
I second this recommendation, the HF 212cc is often on sale for $99 and should fit your compactor better. I've had 4 or 5 Honda clones over the years and just bought a 212 for a go kart. The fit and finish on the 212 is much nicer than the older clones I have and is virtually indistinguishable from a Honda I own. But the best part is how well it runs. I pulled it out of the box, filled the oil, put gas in the tank, set the choke, and it started on the first pull. In fact I'd only pulled the rope about 18 inches before it fired up, that's what, maybe 2 full revolutions? It's a great engine.
2oolhound
BC Canada
You need to consider the weight of the engine. All the springs etc are designed at a certain weight they force up. You can always add weight but if the engine is too heavy the recoil won't be able to bounce it correctly.
I've seen some pretty useless whackers.
