I stopped using an Intedge waffle iron since it was tripping the CGFI breaker (don't think it was tripping the panel breaker). My memory was it would heat, the light would go off until time to cycle back on and when it went back on was when the breaker tripped.
Decided to try again. The only thing I see wrong is the covered part of the power line doesn't go into the body but ends 1/8" outside. The strain relief seems broken, but no damage to the lines inside.
Plugged in and turned on. With a Fluke infrared thermometer set the dial to 350 the plates went right up to 450 and never cycled before I shut off. Would the switch / temp dial part be the problem? Couldn't read the number on it without removing. I don't see anything loose or damaged.
Thanks,
Rich
Thanks,
Rich
