For all of you gurus out there. I'm about to start a wagon build. This will need to be fairly robust, as it will haul around a pretty good sound system. I'll probably frame it out of 2" square, and put expanded metal in the floor/side walls. I'm guessing about 2.5' by 4' or so. All loaded, the thing will probably weigh in the neighborhood of a hundred pounds to 150 lbs.
My question is about the steering. I'm going to put 10 inch wheels on it to make it easy to pull around. Should I build the steering mechanism into the handle, like a regular wagon, or could I just put swivel casters on the front, and non swivel casters on the back? What are the pros and cons of each method?
Thanks in advance!
Thanks in advance!
