Wait time before top coat
kylworth
Houston
I live in Houston, by which is beautiful weather in the 60's. Humidity 43%, no rain all weekend. I am using Sherwin Williams TileClad, flakes and Rexthane top coat. About to apply first coat of base at 6am,then 2nd coat around 11 or 12. Could I scrape and recover flakes this evening and apply a top coat or should I wait until tomorrow for top coat. Drying time wise?
Armorpoxy
Sounds like a bit if a rush, we would normally recommend waiting overnight. If your coating is not cured, you could get outgassing and bubbles in the topcoat.
Best to always follow your suppliers recommendations too.
K
kylworth
Houston
Believe your right after thinking about it. It's 9 now and still 59 degrees. I have to add at least an hour to the recoat time with full broadcast.
LegacyIndustrial
deerfield, IL
The risk is that the base is still out-gassing. If clear is applied too soon you could get a bubble. Touch test is best. If still tacky wait till the next day.
