manioso
I have an older (late 50's, early 60's) Walker 4 ton Floor Jack Model 748 which I picked up about 5 years ago to work on my F350.
Jack has performed well with out any leaks on either the main ram, or either of the two pumping pistons. Only the filler plug (with a breather) leaks a little when you lower the jack.
However, recently (in the past month) the jack has failed to raise a load. Or it starts to raise and then slowly comes down. I checked the fluid, and added some, but still does the same.
I'm inclined to think it is one of the safety valves. Maybe something is under one of the seats, or one of the balls is gummed up or something.
Does anyone have any experience with Walker, and could provide me with some leads. Any help would be appreciated.
