Walker 767 Series D Floor Jack What to do With?
nutjob
NE, PA
Picked this up for $25 and it has been used hard for many years. Biggest concern is the welds that have been added. The link arms on the left side look bent and some welds added. If the jack was bent and repairs made it is still OK to use? I am going to take apart today and do a closer inspection.
The front wheels, shaft and frame are all worn badly and will need bushings and/or welding to fix. The handle and u-joint are also pretty worn out, lots of play changing directions. The back wheels have some wear also but not too bad.
Not sure how much effort I am going to invest in this one, may sell off for parts.
Thanks
Kevin
N
nutjob
NE, PA
I added some oil to it and was able to pump it all the way up. Its confirmed, the jack is bent. The link on the left is bent out. But, I did put it under the truck and it held up the front wheel for over 15 minutes.
I think I will part it out, someone will need some part off this thing.
Kevin
N
nutjob
NE, PA
I took apart the jack, finished de-greasing it and checking over the parts.
I am going to put it in the Classifieds and hope someone needs some of the parts.
Kevin
